2332cc 94x84 scat crank,scat h beam rods, Vw heads by matt berry/Peter herriman, berg 310 cam, eaton lifters(molybdenum wet lube coating) cb dual springs, cro mo push rods, scat 1.4 rockers,deep sump, full flow with phenix braided lines,48 Spanish IDA's on tall matched porter manifolds, k+n filters berg linkage with berg 1/2 adjusters,ceramic coated pistons with molybdenum skirt coating 9.7-1 compression,barrels have been coated with thermal dispersant,Vintage Speed full comp exhaust 44mm,010 dizzy, dog house cooling system with all tin wear,motor has aprox 15000 km since freshen up.
Ace 30 oil and services every1500 klm.
Gear box is a Late 1300 swinger by Dave Buttler stock late 1st and 2nd 1.49 3rd 1.125 4th with 4.12 cwp Crown super diff.All gear box internals except cw and pinnion coated with molybdenum wettable coating including fulcrum plates SAW axles( the old USA ones)t3 brakes berg style mid mount.
Basically bolt this drive train in any bug and you will have a mid to low 13 sec street bug allways have run vpower or bp ultimate dosen't run hot or leak oil!
$10,000. I'm happy to answer any questions thanks for looking .Col
1916baja ·
What the hell col? Why are you parting with this super reliable combo?
tar76 ·
Sad to see this going Col......Bullet proof package tho
WOW. A good deal for anyone. So you were serious. Good luck with the sale mate.
You better edit, your crank is 84mm
Is this the motor you ran at WSID for the VW Drags ?
whathaveidone ·
word on the street is ,he is buying a crysler neon!!!!!!
1916baja ·
I think you'll find it is Craig, he was babying it that day though.. i think he ran a few mid 13sec passes in it at jamboree. Fair enough... neons are cool as 🙅
hellbugged ·
whathaveidone wrote:word on the street is ,he is buying a crysler neon!!!!!!
😂😂😂😂 Oh so true🤪🤪
Stanley ·
I heard he was doing a suby conversion......😀
whathaveidone ·
4WD too!!!!
coletrickle ·
Craig Torrens wrote:Is this the motor you ran at WSID for the VW Drags ?
Yes Craig it's the engine I ran at the Sydney Vw event,Sydney jambo etc. Sorry it's an 84 mm as matty said, it's run 13.41 @97 in a stock suspension bug on real radials.
Also ran 13.0 @ 104 (?) with FK 87 and M/T radials
coletrickle ·
Stanley wrote:I heard he was doing a suby conversion......😀
I'm doing a valiant conversion!
coletrickle ·
Ben your pretty close one of the engines I'm looking at came out of a neon! A NHRA pro stocker!500ci 1360 hp! Still all motor!
Stanley ·
So your busy making a set of wheelie bars from shopping trolley wheels
