Aussieveedubbers 路 Buying, Selling & Swapping Parts
Wrecking 74 pop top S.E Qld
https://forums.aussieveedubbers.com/threads/96517/wrecking-74-pop-top-se-qld
Ian 68 路
Hi All,
Wrecking a 74 pop top, no motor no gearbox ( all ready gone ).
This old girl has lots of good metal left in it but it also has lots of rust !
Front beam and brakes , front and rear still there.
Please no PM's ring the mobile only ta.
Ring either John on 0432 102 498
or Ian on 0414215324
Bus is located in Caloundra, Qld. Bring your angle grinder !
$ depends on what you want I guess but rest assured it's all going cheap or to the scrapper in less than 2 weeks !
JacksonAndDad 路
Thanks Ian for the bits!!, good luck with the rest of her 馃檪
If you happen to take the spring plate housings off I wouldnt mind having a look at the rear torsion bars and rubber 'donuts'
Thanks again,
Tim
Ian 68 路
Tim,
No problem, will get them off today.
Please ring though mate..
Got a few parts off now for anyone interested.
Have a rear bar and brackets, good condition, inspection hatch, slider door cover, CV's and drives and starter motor
Front beam is good , still on the bus though, front bar is ok, all glass and screen still there, it'll be gone in less than 2 weeks so if you want it come and get it.
also forgot to add we have 2 sets of old skool mags, 1 set still on the bus..lovely and retro !.
All in good nick, all going cheap !
Ring only please. NO PM's thanks all
Ian 68 路
Front beam, both sets of mags, sliding mech provisionally sold.
Indicator mech sold.
Still have all the glass and lots of small bits like latches etc.
Rear bumper is off the bus, inspection hatch is good.
If you want something please ring, I can't get to the PC very often and if you don't ring you could miss it.
Ian 68 路
We have now taken pretty much everything off of the bus.
We have all the glass except windscreen and passenger door.
Rear bumper, fuel tank, rear hubs, arms, rear brakes, inspection hatch,dash,wiper motor, wiper arms and still lots of good metal in this old bus. Will go to the scrapper in a week or less.
At this stage we only want collection from Caloundra, see how things go locally and then we may post out down the track.
Please ring the numbers above and we will get back to you, please no PM's or messages on here..ring only. Thanks all.
Also have a 6 ribber box, this box is for rebuild only as can not give an accurate condition on it.
Took a few other bits off today.
Have both visors, brake fluid res and the fans that have a cover at each side of the cab...no idea what they called...on deluxe models they blow air through channels in the doors ? Passenger door gone now and metal being cut this week, this bus is going to the scrapper by Thursday to make way for another project !
6 rib box still here as well...
ring the numbers please, no pm's as I'm not on here to much and will maybe miss the message..
Thanks Ian & John
Ian 68 路
Edited to show whats new and whats sold..
