Subaru Conversion - Handling question
https://forums.aussieveedubbers.com/threads/96542/subaru-conversion-handling-question
Timbo KG ·
Hi All,
I have been seriously considering a Subaru EE20 (Turbo diesel) conversion for my Karmann Ghia, but am concerned about the extra weight, hanging off the rear. From what I can gather the EE20 is about 20kg heavier in total than an EJ22.
I like the idea of a powerful and torquey engine, but not if it results in "1950's American style" handling (ie good in a straight line, but tip toe around corners).
What are people's experiences with the heavier engine? Are there any handling "eccentricities" and if so, how did you combat them. By the way, I'd prefer real world experiences rather than theoretical views.
(or if there is already a thread about this, smack me about the head and point me in the right direction)
Thanks in advance.
pete wood ·
Timbo, great question mate. It's a question more people should ask.
In terms of an answer, let's start with reality.
REALITY; aircooled VWs are chronic understeerers in stock form.
This is the mark of rear-engined cars. ACVWs mask these tendencies by being chronically underpowered and having chronically soft suspension. Linkpins and swingaxle are even worse in this regard giving neutral camber up front and negative camber out back. However, most of this can be easily improved via some simple mods that have kept FVees fast for many years.
What happens when you add a heavier motor to the back? Well 2 things. Like you imagine, the understeer gets worse. However, beyond the understeer with all that extra power, you then get snap-oversteer. In other words you go; plough, plough, plough, SNAP, totally sideways and fighting to stop it pointing the opposite direction. So to go fast it means driving the car with the handbrake and the throttle for the most part.
How to fix that?
1. move everything you can to the very front of the car; battery, fuel tank, radiator, spare tyre, tools, etc.
2. cut off every thing you don't need in the engine bay, lighten the back of the car via speed holes, use lightweight fibreglass panels on the back of the car, get rid of the back bumper, use ali/composites/plastic instead of steel for everything in the back of the car, etc.
3. move the engine and trans as far forward as humanly possible.
This last step is the hardest and means you need IRS. It's major surgery and not for the faint hearted, but lots of people have done it.
If you do all this and get it all right, you can end up with a car that has a 50:50 front rear weight setup. I spoke to a porsche rally car owner years ago and he said they managed the 50:50 weight split without too many dramas. It just means thinking hard about everything you put on the back of the car. Of course if you manage 50:50, the car will handle amazingly.
Your trying this with a ghia will be much easier than my struggles with a buggy. Even still, the buggy showed a marked improvement as I removed weight from the rear, stiffen the rear chassis and moved heavy things forward.
Hope that answers your question.
HappyDaze ·
^^^^^EVERYONE with a rear-engined car should read this.^^^^^👍
ian.mezz ·
mate dont waste your money on a Turbo diesel.🤪
HappyDaze ·
ian.mezz wrote:mate dont waste your money on a Turbo diesel.🤪
Unless, of course, you want to win Le Mans 24 hrs.😂😂
I'm pretty sure that the Subaru engine uses a CAN BUS system to run the motor.
I think http://www.alldrivesubaroo.com.au/ are working on a system for late motors like that to work in earlier cars.
Good explanation Peter, you cant drive all differently configured cars the same way. No matter what sort of rear engine you have you will have understeer on tight low speed corners, it all comes down to the nut behind the wheel.
Subarugears ·
All drive Subaroo have finished defeating the CAN bus on late model ECU's - petrol or diesel. It's just a matter of getting the ECU flashed. You can also get a stand-alone ECU for the EE20 diesel - made by Hurricane. I hear that Bosch ECU's work on the diesel's as well. Lots of options really.
For handling - battery, radiator in the front for a start.
ian.mezz ·
🥲in the current economic climate its not economical to put a diesel motor in a petrol car the cost far out way the returns.
sand bags 😊
I have always found our Beetle to handle heaps better when there are three slabs of beer in the front
vlad01 ·
pete wood wrote:Timbo, great question mate. It's a question more people should ask.
How to fix that?
whats the weight distribution of a bug?
^ All this sounds scary if its true 🤪
It actually sounds like what my buggy I used to have was like. Thankfully the late type 3's are nothing like this, well maybe a little pendulum effect on loose gravel but my daily front engine car is 10 fold worse on anything but bitumen so I guess that doesn't count?
I bet a 1303 would be sweet as.😍
SebastienPeek ·
Vlad,
Got Zelda completely 180 degrees in the wet the other day.
Definitely a lot difficult to handle than a FR car.
As soon as an RR car builds up momentum in the rear, all hell breaks loose.
Especially in the freaking wet and no tread on the rear tires!
Will definitely be looking into getting the weight distribution better and what not.
bajachris88 ·
Dubster's 1303 has a consistant desire for oversteer in the wet and hasn't nabbed either of us in loosing it.
Even without trying, the rear end loves to go out before any sign of understeer is present. I guess the strut front and IRS helps massively, but the front is also lowered with some pretty beastly sway bars at the front too. It has stock tyres/wheels. Different kettle of fish compared to old swingaxle/beam front. 👍
HappyDaze ·
Take a look at the position of the jack point, in relation to the front & rear wheels, and that will give you some idea.
modulus ·
pete wood wrote:... aircooled VWs are chronic understeerers...
I agree with all of the practical advice that Pete has given.
However, the explanation is a bit ropey. Additional weight at the rear of a car will tend to cause oversteer rather than understeer. As can be seen by that later comments on 1303's etc., this is the case with IRS/ball-joint pans. The tendency of early pans to understeer at moderate speeds is owed to the overall suspension design in conjunction with the weight distribution, probably by 'intelligent design'.
Whilst 50/50 is an admirable goal, it is worth noting that the latest Porsche 991 C2 is 42% front / 58% rear, exactly the same as the Ferrari 458 Italia. Both are able to go around corners.
hth
pete wood ·
Good point modulus.
However, the oversteer is SNAP oversteer and preceeded often by some understeer too.
Something else to remember, MR (mid engined, rear drive) cars are also natural understeerers. That's why they are "slow in, fast out" cars. You brake hard, turn in and then accelerate out. Watch some of the mid engined cars on Topgear and you'll see what I mean. If an MR car gets out of shape, it happens fast is usually very hard to catch. Again some of this comes down to setup, but wherever you put the weight, that's what controls the physics. If you want a well balanced car (rather than a "drivers" car), like an RX8 or MX5 for instance, you go as close to 50:50 balance as possible.
Course there is a way to "drive around" the understeer. It involves lots of chucking the car round and lots of power. It's called "drifting". It's not usually all that fast. 😉
Vlad: "Thankfully the late type 3's are nothing like this"
Sorry to rain on your parade, but they are much the same as every other ACVW. Look where the car suspension sags over the years... that's where the weight is. Lbugs too. The difference being, you can change your front camber easily.
bajachris88 ·
In other areas, what was interesting is that on road or even in mud (low traction conditions) the baja is 95% time was riddled with mass under steer. My thoughts was the light weight of the front (which causes the front brakes to lock very easily too i noticed) would loose traction and just 'plough' in the direction of motion. I guess the 10.5inch wide tyres on the rear is what keeps the oversteer from peeping up.
Mind you with alot of effort, once you do get the rear spinning (in the mud), only then i can get oversteer to come about. 👍
ElusiveStranger ·
helbus wrote:I have always found our Beetle to handle heaps better when there are three slabs of beer in the front
But what do you do at the next junction? 😉
Gotta say that Pete W and Modulus have some very valid posts that really should have a "+ 1" from me
Timbo KG ·
Hi Everyone,
Thanks for your comments. I have read and re-read your comments many times. Pete and Jak, your comments were particularly informative and have influenced my decision to give the turbo diesel conversion a try. I know I have to rethink a couple of things, but I think it should be do-able.
I know that economically it makes limited sense (and the further I get into it, the more extra costs seem to emerge), but if anyone has driven a modern turbo diesel recently, you'll understand that they have great characteristics for the street. Lots of torque down low and deceptively quick. Now, take a couple of hundred kilos from the original vehicle and it should be a lot of fun.
I'll start a build thread soon, once some building actually starts. I'm sure no-one wants to read pages and pages of degreasing and chassis painting, etc. I intend on outsourcing key parts of the project, but want to wait for the right people to be available, rather than paying for work I'm unhappy with. Unfortunately, this means there are already lengthy delays (including this reply, sorry).
Thanks again, Tim
pete wood ·
A TDi motor will probably heavier than a subaru NA for a few reasons.
1. the blocks are usually iron to account for much higher compression
2. inline 4s (unless you are going subaru TDi) are longer and hence have the weight further back.
I'd actually advise against going with a TDi motor in KG for your average conversion. Coz unless you plan on building a specially designed tall ratio trans, you're not gonna get the value out of the TDi you would in factory car. To give an idea of the sort of revs, my Pug 307 diesel does only just 2000rpm at 110km/h (70mph) in 6th gear. You'd need a very tall gearset in a beetle box to get close to that. Now if you do LOTS of freeway miles, it might be worth it, but otherwise not. Modern efi EJs are pretty good and if you want better fuel economy you could put an aftermarket ECU on and tune it really carefully.
ian.mezz ·
my EJ 20 bug uses 7.5lt per 100Ks
good luck .😊
Subarugears ·
This project is getting a Subie EE20 turbo diesel and a Subarugears 5 speed to suit. Going to be a helluva combo.
ian.mezz ·
don't you think to be moving forward and you want to do something better , you be going electric. Rather then a rattly diesel.
Diesel cars ain't big sellers in Australia.🥲
I guess we have to wait and see if or when you finish it.
waltermitty ·
Jak Rizzo wrote:I tracked my car for 10 years before going WRX power & I couldn't tell the difference from before & after,
Jak
So the WRX conversion made NO difference!
Mitchell
waltermitty ·
Jak Rizzo wrote:
Jak
Mitchell
To the handling no, which was my reply the to the original question re: the additional weight hanging out the rear of the car
I know what you meant Jak just taking the piss , as you know, it didn't take you long to bite though ! *) Mitchell
Subarugears ·
ian.mezz wrote:don't you think to be moving forward and you want to do something better , you be going electric. Rather then a rattly diesel.
Customers car - they can do whatever they want, I just supply the gearboxes.
vlad01 ·
HappyDaze wrote:^^^^^EVERYONE with a rear-engined car should read this.^^^^^👍
+1 i always do this 👍
vlad01 ·
Subarugears wrote:This project is getting a Subie EE20 turbo diesel and a Subarugears 5 speed to suit. Going to be a helluva combo.
with all that torque its gona haul ass!
pete wood ·
You're kidding, right Mezz? Electric seems cools until you have to replace the batteries, which a. weigh a tonne, b. cost a bomb, and c. are awful to the environment. All that plastic and acid comes from fossil fuels and mining just like everything else. However, a diesel will in most cases outlast the bodyshell it's put in and when the motor wears out, you just melt it down and recycle it all. What do you think happens to old battery acid?
This is the problem with electric cars. They're a massive marketing lie. Only honda have got close to solving this but it's still not cost effective. Everyone else's prius is killing baby furseals and melting icecaps just the same way commodores do...
Don't get me wrong, I'd happily drive an electric car, but only if it's actually as friendly as they say.
Subarugears ·
Ironic, there's talk about moving forward, but in a 60 year old car that has none of the hundreds/thousands of improvements that have been incorporated into cars over that time.
Who's trying to kid who?
pete wood ·
Nah, I'm committed. I bought a diesel family car for all these reasons... and besides, they sound cool. 😉
lou0060 ·
horses for courses. Personally I wouldn't put a tdi in a kg as if I was going to convert a kg it would be as a road rocket and with all the room in the back you could go to town with an STI.subgears combo I reckon. And it would be pretty fuel efficient as the kg is a relatively slippery shape compared to a bus or even a beetle. However, if I was going to do a bus then a tdi and auto suby box would be nutts.....
my daily is a tdi T5 and I drove it from Bris to almost Newcastle towing the race car on the way to Wakefield before having to fuel up and last year drove from Redcliffe to Liverpool before having to fuel up, (no trailer this time) so I am all for the tdi conversion but not sure about doing it to a kg.....
However, everyone bagged me for putting my radiator in the back of the beetle too so I guess go for it and I look forward to some pictures.
modulus ·
lou0060 wrote:...as the kg is a relatively slippery shape compared to a bus or even a beetle....
Wash your mouth out with soap!
Beetle CD: 0.48
Caravelle/Transporter: 0.37
Karmann (FHC): 0.37
So you should say:
...as the kg is a relatively lumpy shape, comparable to a bus, but nevertheless way better than a Beetle....
The (original) VW Beetle is a beautiful shape, as long as we define beauty in terms of aesthetics and not function; the aero drag is a significant limiting factor on top speed. The KG had a reasonable CD for a design of its time, but today a 997 Porsche is around 0.28.
hth
Timbo KG ·
I know that the TDI conversion would be better in a Kombi, but an old Karmann is all I have. . . .
ian.mezz ·
Timbo KG wrote:I know that the TDI conversion would be better in a Kombi, but an old Karmann is all I have. . . .
Well get stuck into it and get it finished, Once its all together then you see how it handles.
As a lot of people on car forums seem to start things and never ever finish them and lose heaps of money and end up selling all the unused stuff on EBay.
The things I don't like about Diesels is you need a bath after filling up, they stink and get some bad fuel in a modern Diesel and your deep trouble.
nbturbo ·
Found this-a good read.Did it ever happen?
57 oval ·
Ye good one NB, read the whole thing before I realized it was an old one. Would be good to hear if it happened, better still pickup the " unfinished " project and run with it. I know of a few people that have a dream, start it get bloody close to the end and park it in the corner. Get back to it
nbturbo ·
Want me to loan you some bumpers to finish another project??
57 oval ·
Na its OK thanks, don't think I will fit them, with the wider guards and standard bumpers it will look like that girl that walks down the mall with her size 10 gym pants and a size 16 body, to much body hanging out each side. Now get back in the shed
nbturbo ·
Woah 57 Oval- good thing Gillard doesn't visit here- she would tear you to shreds for a comment like that- I can't even spell what she would call you.
