I have another engine here that I have finished and is complete from the front pulley to the flywheel and from valve cover to valve cover . This engine has been assembled using 100% brand new components ;
Magnesuin case bored , decked and clearanced
Empi 78mm 4340 forged crank
AA forged 5.4" I beam rods with 3/8" ARP 200 bolts
Engle Fk 44 cam and magnesium gear [ 262 @ .050 and 489 lift ]
CNC ported 044 heads with 42 x 37.5mm stainless valves and dual springs
Scat 1.25 rocker kit with swivel feet adjusters
Manton moly pushrods
Scat stainless steel valve cover kit
Shadek 26mm oil pump
AA lightened moly flywheel
AA 44mm gland nut
Scat solid lifters
Stainless steel pushrod tubes
Empi bearing dowells
Scat crank gear kit
Century case install kit
Century dizzy drive/shims and spring
Scat moly 8mm head stud kit
Century cyl. deflector tin
IAP 009 distributor and clamp
Mahle main bearings
Clevite rod bearings
Mahle dual thrust cam bearings
Elring gasket kit and rear main seal
This egine is located in Wollongong NSW and is priced @ $ 5065 and can be shipped Aust wide . It has a comperssion ratio of 8.3:1 and will suit and type 1 , early type 2 and all type 3 vehicles , ROD , 02-42729920 .
RodPenrose 路
