kombi front end adjusters pic wanted
https://forums.aussieveedubbers.com/threads/9674/kombi-front-end-adjusters-pic-wanted
koolkarmakombi ·
Hey all,
anyone got a pic of a kombi (bay)front beam with adjusters welded in?
kkk
11CAB ·
http://www.kruizinwagon.com.au/upload_images/Adjuster_fig_12.jpg
KruizinKombi ·
And if you need a pic of them unfitted, let me know. The set I bought from 11CAB at Nambucca are still sitting in my shed next to the installation instructions. :thumb
[Edited on 23-8-2003 by KruizinKombi]
koolkarmakombi ·
thanks for the link, and yes Kruisin, I would love to see the piccies. Just thinking of doing it myself -v- getting it done. Will prob use manx buggies if I get it done.
Hey Colin,
Are you using yours to go up or down?
I think I already know the answer.:alien
KruizinKombi ·
Down. 😎
Although, after getting bogged trying to hook up my trailer today, I could be tempted to instal them so that the centre setting is stock, giving me a few inches adjustment either way. :thumb
koolkarma, here's a pic I found last night on the net...
kombi_kid ·
get ready to get dirty!!!! u have to pull the beam out pull out all the leaf springs and then clean every bit of 30 odd years of grease!!! then grind down the little lobes do the manx buggy ones come with the adjustable bump stops??? because if u are going down lower the 4 inchs i would reccommend them!
rhys
koolkarmakombi ·
AAAh adjustable bump stops.... Need a piccy of them too.
Why do ppl talk of adjustable spring plates on the rear instead of adjusting the tosion bars a spline or two?
Gotta love t3 suspension. Just twist them around and down/up it goes.
kkk
11CAB ·
The idea of the adjustable springplates is that you fit them the same as if you were adjusting the splines, then when its all back together you can adjust the ride height whenever you want without having to pull it all apart...
:thumb
kombi_kid ·
adding to that its also easier in my case to jack the car up and change height so i can change my rear wheel!!!
ill get a pic when i can!
rhys
Newbie ·
i have been looking at kombi lowering kits.... how low is 50mm???... kombi_kid's and crazyfiggi's vw's look awesome😎... just how low are your vw's???...
I was wondering if there was anyplace that i could talk to about lowering a kombi in brisbane... i know there is Indian Automotive but was wondering if there was anywhere closer to home??
Does lowering a kombi mean getting a modification plate???... and would it increase insurance premiums???
[Edited on 28-8-2003 by Newbie]
bugboymatt ·
Hmm i'm trying to get the mrs to let me raise hers and stick some larger tyres on :bounce
kombi_kid ·
hey
i dont know how low i went i think its something around 5 inchs i would go for around 3 inchs its a good height!!! with adjustable bumpstops u dont need to fit them unless u go over 4 inchs.
in the indian automotive kit he says that he roccomends to get the engineered certificated just incase u get instrife by the police (i will be targeted by the police here like every other P plater with a lowered car with rims)
i would ring kimm at indian they do an excellent kit!!!
rhys
byronbus ·
custom bugs and buses at penrith do kits as well, they often send stuff to brissy, i think hardings fit them if you dont want to do it yourself...
[Edited on 30-8-2003 by byronbus]
Newbie ·
thanks for replying so soon.... i think that i would proberly only go 3inchs i dont want to sacrifice to much of my ride quality... but i wish i had the guts to go as low as you!!!...
I will get in contact with custom bugs and buses too... thanks
baybuscamperkid ·
i too want to go a little lower, purely for stability reasons. how low should i go (without sacrificing ride capabilities) and what is the cheapest way to do it?
KruizinKombi ·
Cheapest way is to stick to 2 or 3" and use Angus adjusters on the front, and reset the splines on the back. You won't need to alter brake lines, shockers or anything, but you will need to do a wheel alignment.
I'm not sure that such a mild lowering job would make much difference to stability because I haven't done mine yet. You'd have to ask somebody that has. I personally feel that if stability is what you are after, you should focus on things like wheel bearings, steering box, balljoints, tie-rod ends, trailing arm bushes and the like. If its still not good enough after you have everything up to scratch, then consider lowering. 🙂
modulus ·
Agree with what KKol said PLUS tyre choice.
I'm running Michelin XCD Light Truck tyres at 40-45 psi, and have found that they suit the stock suspension very well
hth
kombi_kid ·
ok sorry bout the delay!!
adjustable bump stop:
