Beetle Chassis + Body lineup
https://forums.aussieveedubbers.com/threads/96911/beetle-chassis-body-lineup
DubLeg ·
We all know you can lift and change the bodies on beetles. Is there any limit to what years you can change it up?
Can I change a pre '67 body with a post '67 body?
yes they will all fit except for Strut bugs 71 to 75
Sides ·
As Dave says above they'll all fit other than strut bugs - pretty common to put a later IRS pan under an early body.
One thing tho is that upto 67 and 68-on are different around at the body mount at the rear shock towers - the hole will line up, but you'll need to raft the bracket on the body either higher or lower depending on the combo.
