Hi there
I am looking for the tow bar that is the winner on neat, functional and barely noticeable.
It will go on a lowlight (fabricate it myself) so if any lowies have tow bars that will help even more.
Look forward to your input.
Marcus
grinderman 路
Damn..........if its for barely noticeable mine is crap, but for functionality (especially strength) my lowlight rear bumper/towbar/step is hard to beat. I had an engineering firm modify a haymann reece rodeo removeable hitch towbar (rated at 2800kg) with tube sides and a checkerplate top. They also welded some 8mm thick tabs to the chassis to boost the mounting points to 4, so I am confident the towbar could pull 3 ton but the 1835 engine might have something to say.馃檯
11CAB 路
You need to check out Andrews towbar he made up for his BajaBus. Best Towbar I've ever seen on a kombi
11CAB 路
Some pics.....
vassy66T1 路
Excellent pics thanks 11cab
That is exactly what I wanted to see. I was thinking of the square hayman reese style tongue connection through the bumper.
The gussets around the "up and down" are very well done and a great idea.
Good to see it can be done.
I have just got to try and fit that into a lowlight bumper. That is the challenge for me.
11CAB 路
The way Andrew has done it allows the bumper to sit nice and close to the bodywork which doesn't happen with the normal kombi towbars
