Aussieveedubbers · Bugs
axle seals
https://forums.aussieveedubbers.com/threads/96956/axle-seals
JohnnyMac ·
Hi guys, I'm replacing the leaking axle seals on my 55 running a split case. Does anyone know of the best place to purchase? Are some better than others?
John.
make sure you flatten the seal housing on a glass plate with wet n dry paper before fitting the new seals
they get over tightened and you can fit 10 new seals and they will still leak
also clean the gasket and sealing surfaces on the brake backing plates
use fine wet n dry on the bearing spacer to remomve wear marks from the old seal
good quality seals available from VVDS in Sydney 02-9789-1777
There is a good reply
JohnnyMac ·
vw54 wrote:make sure you flatten the seal housing on a glass plate with wet n dry paper before fitting the new seals
Thanks very much! Awesome help 🙂
