Any experience with...?
https://forums.aussieveedubbers.com/threads/96995/any-experience-with
SebastienPeek ·
Hey all!
I'm just wondering if anyone has had any experience with installing electric speedometers into their Beetles and it so, what sort of application did you use?
Did you get a mechanical to electric converter kit?
Or did you do something like a PNP sensor?
Just doing some more research into some options I have.
To be honest, don't necessarily want to get rid of the speedo cable from the original application as it means I can go back to stock quite easily if the time comes.
Seb
cam070 ·
Vdo used to make a hall effect sensor that I think will allow you to run both. I can try and get the part number from mine in a couple of weeks if you are interested.
Joel is using a headsup display from these people, they also have sensors. http://bluewiremotorsport.com/collections/speed-alerts
I wouldn't worry too much about a sensor till you find out what signal the cluster needs.
I'm pretty sure the late Subis are 5volt PNP
SebastienPeek ·
Thanks all!
Joel, I'm going to take your word for it, that it is a PNP 5 volt signal needed.
If this is the case, my plan is to copy your setup with the NPN sensor and get an inline NPN to PNP converter and lot regulator to get it to the speedo correctly.
Woot 🙂
