71 super modified DOVW 1st place winner 2011-2012
https://forums.aussieveedubbers.com/threads/97075/71-super-modified-dovw-1st-place-winner-2011-2012
Uncle Barry ·
This is a sad day for me, how ever a good day for the new owner.
1971 advocardo green super
1915 All NEW engine. God were do I start.
Dual 40mm completely overhauled Dellortos. electric fuel pump and braided lines. steel filter. New 55amp alternator, all new chrombe tin wear, alloy pushrod tubes with chrombe molly adjustable push rods, alloy cb performance rocker covers, 1.25 ratio hd rocker gear .50lift
New interior, new wheels, brakes, HD clutch
Motor, new, bubble top case, oil filter hd pump, counter balanced 69mm crank,
eagle 110 can lubrized lifters, 94mm pistons and barrels,
Lightened flywheel, cam gears, heads are MOFOCO 050 D port, follow the link below. 42mm inlet and 37mm exhaust stainless steel valves. Arsome heads breath amazing.
http://www.mofoco.com/item/MOFOCO_050_Big_Valve_Air_Cooled_VW_Cylinder_Head/234/c52
Matched ported offset inlet D manifolds
Serpentine belt set up, Electric ignition with dial in rev limiting module. Stainless steel fat boy exhaust.
This is one noisy machine. real head turner. Induction noise is incredible. New cv's joints. rear shock, tacho, oil temp and presure gauges, new gear lever, new carpet, new red seat belts frt and rear.
I built this to put a mild turbo on her and have all the exhaust, pressure duct work and pressure hats to suit. Just a small .42-.46 turbo and your set. Have all the oil feed lines remote filter set up. oil breather canister.
New wheel bearing frt and rear, brakes new all round, new calipers, new frt adjusterble strut and gas cartridges.
New brm chrombe 4.5 frt and 5.5 rear wheels. new tyres.
new steering tie rod ends, ball joints, completely detailed under neath.
new battery and leads, new 3chamber halogen head lights,
new hood lining, needs a couple fitment tiedy ups. new visors, mirrors, taillight lens new, tbars,
two pac paint which cost $4.5k alone and all rust removed and welded in pans.
God what else......... think thats it. 2 years in the making and over 20k spent in parts including the purchase of the car. Try and do one for this money.
Sell $18k firm no tyre kickers. Do your home work and understand what has been done here.
Greewith SA 0448866248 rego sabc123 need to check
If your interested in something really special than this is a 2 year back to back 71 1st placed day of the volkswagen modified winner. Has been in the vw magazine twice. trophies will not go with the car.
https://www.facebook.com/media/set/?set=a.150968558299781.34716.100001599136357&type=3&l=5499afa72a
some more pick links here.
https://www.facebook.com/media/set/?set=a.135231639873473.27221.100001599136357&type=3&l=792c781fa7
man i think of the boxes and boxes of gear i imported from the us on this. New window rubbers, new laminated top tinted frt screen. all doors window trims, rubbers replaced,
new winders, new indictor electronic relay..... now i am getting carried away now... thats enough for now.
DUB64 ·
drool more pics please inside etc
Uncle Barry ·
Check out the two face book pic links. I dont know why they are upside down
smithy68 ·
How many km's on the donk?
Also who built the motor?
Nice looking bug!
vicelore ·
You can spin pics in your photobucket account..
Uncle Barry ·
Offers over 15k considered.
chris7 ·
Nice car !!
