vvwbeetle wrote:Hi,
Could anyone explain this?
Today it seemed every time I wanted to use the brakes I had to pump the pedal to get it to have a better feel to it.
Brake fluid is full.
What should I be checking?
Firstly has this just happened?
no work has been done on the brakes?
as it sounds like You have air in the brake system...
Air is compressible whereas brake fluid isn't...
does the pedal move when You pull the hand brake on?
Do You have a single brake system or a dual system ?
[dual lines and dual master cylinder]
You can tell by the master cylinder... if it has two pipes/hoses coming out of it its a dual system...
but as said, a leak is usually easy to see as there will be brake fluid where its leaking... check all wheels and the back of the brake drums etc..
