Do o'brien do L bug screens? or other ppl in brissy? and how much, any idea? thanks bix
Robo ·
This probably is not much help, but I got a new laminated screen for my 77 Kombi (Moran) it has a blue strip at the top, for $150
Rob.......
Any windscreen place should be able to do it.
The going rate is between $165 and $185.
That is supplied and fitted. 😎
bugboymatt ·
Snap on that one Rob me too.................
Robo ·
Where did you score yours.?
Rob....
Pat ·
Make sure you get an Aussie made one, the cheaper Chinese/Indonesian Screens de-laminate (the two glass panels split apart) after a while.
Quickbug ·
Years ago when i lost a L bug screen on a trip away, Obriens had one in stock, supplied and fitted for a bit over $200...
Didnt have time to argue price since they were the only ones around that had one in stock...
Make sure you fit a NEW windscreen rubber to the New glass otherwise you make have unwanted water leaks...
To replace the rubber after its already fitted may crack your new windscreen so buy a rubber as well...
Didnt yr MUM tell you that a long time ago,,,, buy a rubber.
And under no curcumstances let them use windscreen sealant. It blocks the drain holes and causes rust.
