Has anyone had any luck recently finding a replacement exhaust for a 2.0l Kom ? I raised the question on the forum a few months ago and was shouted down by enthusiasts for the stock system. So I bought what I was told was an original, and now the fuel consumption is down to 23mpg, from 28mpg and it won't pull up Lapstone hill (Blue Mountains area) in top any more.
Robo ·
I stopped mucking around with mild steel systems and got a SS extractor made up! cost me $500 but when you take into account you only get 2-3 years out of a $250 MS one I think it was worth it!
Rob......
Andy ·
Nitram_Ztilad,
Reading your old post I assume you have an otherwise stock 2L dual carb motor??? No mods??
Strange your experience conflicts with the experience of others. 28mpg does sound unusually high for an old Kombi though.
Can you not source the exhaust you used previously?
I know of some one with an SS extractor exhaust for a type 4 (custom made). Not sure if it's complete or if it bolts to the stock heat exchangers. I can find out if your interested.
Do you still have the heat exchangers, or did your previous system replace the whole exhaust system???
Andy :thumb
Robo ·
Hi Andy.
Mine bolts up to the OEM heat exchangers, inch and 5/8 ss tube, I wanted a SS muffler on it, but when I went down to pick it up, he had a SS hot dog on her! I took it home and it has grown on me now and I actually like the sound, very crisp down low and quite at cruising speed, it must be OK Alan at Stokers loves it so it must be good! :thumb
Rob......
mnsKmobi ·
28 mpg from a 2l kombi??? Tell me what I have to do! 😀😀
Andy ·
That exhaust is for sale by the way. I don't know any details but can find out if some ones interested.
I'm a fan of the stock sound myself, but that's all I've ever had :thumb
I agree with mns though, 28mpg is VERY desirable.
Nitram_Ztilad ·
28mpg was in a 1974ish 2.0l dual cab, with two adults-otherwise unladen. I drove to Forbes from Springwood via Orange and back via Canowindra and Blaney the next day. We travelled at about 85k/h all the time, and I don't push it hard on the hills.
The car is standard carbureator engine, other than the exhaust which was a Thunderbird quiet muffler, but I had removed the quiet bit and replaced it with a hotdog. It's a bit noisy outside, but from inside it's nothing more than a pleasant growl that lets you know it's working.
With the "stock" muffler (which I'm now told was made in Sweden or somewhere other than Germany) it doesn't pull from down low anywhere near as well, doesn't hold on on the hills, and when cruising on the flat you need more throttle to maintain the same speed. The whole feel of the motor is different and anyone who reckons it's all psychological is probably an RTA employee on a mission !
We also have a '77 2.0l Microbus that we took to Tasmania last Xmas. It's stock other than a Crane electronic ignition and with that semi-home made exhaust will also get excellent mileage on country roads where you're in top most of the time if you don't cane it along. If you thrash it or tow a trailer then the fuel consumption goes through the floor.
Andy, I'd be interested in that s/s system. I'm using the stock heat exchanger headers so I'm looking for something to bolt onto the back of them. Get the owner to give me a call on 0412 169255 anytime.
Nitram
Andy ·
Will do :thumb
Andy ·
Ok Nitram_Ztilad,
Details so far are, SS pipes with tuned length, bolts onto stock headers/heat exchangers. Never been used. They are a custom unit, muffler is part of it also (all one piece). The person that made it has apparently made a number of them, so has some experience. Don't have any details on what it does for performance or noise etc. though. It fit's where the stock muffler is and will not take up much more room if any.
He said that he wouldn't budge from $600 though, apparently cost him more than that to buy some time ago. Not sure what freight will be for you, ~$50-100 maybe??
Let me know if your still interested and I'll organise it for you.
I might even be interested, as Robo said they will certainly last well.
If your new stock exhaust is good (brand etc) I'd consider some sort of exchange also?
Andy :thumb
Robo ·
Hi Ben
I rang Genie, couple of years back, and they said they didn't make them! although I remember seeing an advert for Kombi SS extractors in the early 80's.
Did you have to get them to start remanufacturing, or has it been continuous all the time! would have saved me all the hassel of getting custom headers made.
Rob......
[Edited on 29-8-2003 by Robo]
Nitram_Ztilad ·
Thanks Andy, but I think $600 for even a s.s. exhaust goes beyond what my current domestic arrangements could tolerate.
Ben, So how does one contact Ben Durie Auto Eng ?
Nitram
KruizinKombi ·
You just did!! 😀
Ben Durie Auto Engineering
2 Park St Teralba, NSW, 2284 Ph: (02) 4950 8248
Andy ·
No worries, I thought so too. He can keep 'em for a while 😉
Nitram_Ztilad wrote:Thanks Andy, but I think $600 for even a s.s. exhaust goes beyond what my current domestic arrangements could tolerate.
