Aussieveedubbers 路 Offroad V-Dubs
Now have tubes in tyre, any new offroad driving does and don't's?
https://forums.aussieveedubbers.com/threads/97320/now-have-tubes-in-tyre-any-new-offroad-driving-does-and-donts
bajachris88 路
Yay! Finally got tubes installed on the front tyres after being haunted with a slow leak that would leave me contantly inflating and worrying.
Now... I did have Jeff Hibbards buggy book but it got too well used and fell to bits. I do remember driving tips for tubes being in there but i couldn't recall em'. Now that its relevant would you lads have any recommendations on minimum pressure for sand driving and do's / don'ts when it comes to running wild with tubes fitted?
All help greatly appreciated!
That puncture repair kit is now obsolete, time to pick up some patches 馃憤 And lets hope i don't get the fun of trying to pry off the tyre to repair a flat too soon.
Chris 馃檪
h 路
when the weather is warmer sounds like an arvo of mud n bush tracks up this neck of the woods chris 馃槈
68AutoBug 路
Hi Chris
I wouldn't have tubed tyres on a car..
and have seen the tubes go off like a gun straight out the the side of the tyre... and the tyre goes flat immediatelly
as the tube has a large hole in it...
Rem,ember that a small nail going into a tubeless tyre does very little damage and can be repaired or can have some of that fix a leax stuff to fix the tyre...
small nail punches a tube, it can go off like a balloon leaving it blown to bits...
I would stick to tubeless tyres with the tyre inflater put into the tyre,,,
Of course if tyres are coming off their rims then maybe tubes would need to be used...
bajachris88 wrote:Yay! Finally got tubes installed on the front tyres after being haunted with a slow leak that would leave me contantly inflating and worrying.
Chris 馃檪
bajachris88 路
h wrote:when the weather is warmer sounds like an arvo of mud n bush tracks up this neck of the woods chris 馃槈
Would be an honor Paul 馃憤!
You'd have to show me around 馃榾.
Yea its always a worry Lee. Couldn't afford to have the rims sealed, but on the bright side if i hit a sharp shallow rock and it punctures the tyre, as long as it doesn't hit the tube i'm okay.
Got the spare tucked in the front ready to go. 馃憤
shaned 路
If it is your rim leaking you just paint the inside of the rim I had a rim that was repaired that leaked and had to paint the inner they do that on race rims as they are so thin they leak if not painted inside
pod 路
most tyre places have some black stuff they can seal the bead with if thats where they are leaking from,had to use it on my sons commy as the chrome on his mags was peeling,so a bit of paint then bead sealer ,not gone flat since :-)
bajachris88 路
Thanks guys. The rims are two piece, that is a steel outter with an alloy centre. The alloy centre is allen keyed into the steel outter but it so tight i'd need a blow torch to unlock it up.
the leak was one one rim, at the joint where the alloy spoke meets the steel rim. But its ok, i'm happy to run with tubes for the moment.
he bloke at bridgestone Loganholme said he had a mate that could repair the rims to stop them leaking. It was something expensive, like $200 a rim that left me pretty disheartened. Mind you this is the mob that wanted to charge $35 for tube fitting and balancing, only to tell me the next day that he rekons it was unsafe to put a tube in but couldn't give me an excuse. Then went on to sell his friends services lol. So went to good old bob jane at Beenleigh (where i should have went first) and it was $25 a wheel with no problems at all. There shouldn't be any safety concerns anyways because i been running the same rim (only different size) with tubes on the back 31x10's since day dot of baja rego, and its seen quite a few kms. (coffs trips, kempsey, warwick, noosa, straddie, toowoomba etc.)
68AutoBug 路
Hi Chris
You may not have any problems at all and it probably wouldn't take much to seal that leak in the rim
I haven't heard of that happening before but it probably does
same as normal steel or alloy wheels can leak..
most cars I've had have had at least one tyre that always went down slowly and needed pumping up every week
although all cars should have their tyre pressure checked every week or two at the most anyway..
If You get a puncture when running low pressure, You should be able to pump it up with a 12 volt high pressure pump
I bought one on ebay cheap... they are usually called 4wd pumps. and I see twin cylinder ones about too.
If You are lucky You may never have any problems...
shaned 路
so it leaks on the joint . $200 to fix wat a rip all it needs is a bead of silicone around the join on the inside should always be done on 2 piece rims 2 minutes work
