is it possible to run a wasser boxer just for drag use without water or do i go into the expence of converting it to aircooled and if so who does the stud conversion here in australia and other machining needed
stevo
SuperOwen ·
Any competent engineering shop can change the head stud pattern, although I'm 99% sure stock wbx pattern is the same as 4inch bore pauter autocraft etc, which may be a better option for a drag engine? I think you'll also have to remachine the case barrel spigots to take whatever barrel you end up using.
