Would This Speed Sender Work?
https://forums.aussieveedubbers.com/threads/97474/would-this-speed-sender-work
Oppressa ·
I need a hall effect sender for a new speedometer I am getting. Would any of these suit a 1971 Beetle?
http://www.ebay.com/sch/i.html?_nkw=hall+effect+autometer&_sacat=0&_odkw=hall+effect+sender&_osacat=0
vwo60 ·
I run one of the autometer senders with a autometer speedo, a bit more information is required to match the speedo to the sender, what is the speedo. also you have to apapt the sender to the cable, i machined a nylon one for mine. there is one available on line already mated to a beetle speedo cable from one of the sellers on ebay.
If you don't mind a small amount of fabbing, its not hard to make one up.
I fitted a hall effect sensor on my rear axle to operate my digital speedo and my Engine management needed a speed signal.
It was just a $25 proximity sensor off ebay and some scrap metal I had lying around.
Off the rear axle works better too as on a dyno the front wheels aren't turning.
