Well I've had poor fuel economy for a long time and could smell fuel every time I parked My car in the shed..
this is the reason....
When I took the tank off I didn't see any fuel leaking...
paint was over the top of the holes...
but I could see where there had been fuel leaking onto the chassis... so I took the fuel pipe and fitting off to see if it could be leaking... tried adding rubber seals and refitting but fuel Was now leaking.. so tried all sorts of ways to try to stop the fuel leak... after a few tries... I started to wonder if it really was leaking... and found the fuel coming from a different place... so, I wire brushed the bottom of the tank after taking the fuel sender out and taking all the fuel out...
one hole appeared and then another.... I went to the local parts shop for a fuel tank repair kit and He sold Me a two pack epoxy kit [made in usa]...
I cleaned the inner holes and the outer holes [same holes really] with alcohol wipes.. then mixed the two pack epoxy and did the inside first.. on a long screwdriver.. lol
then did the out surface.. sat it in the sun.. after an hour I gave it another coat on the outside and later another coat on the outside..
The holes were actually in the lowest part of the fuel tank..
[where water would collect...]
No More fuel smells and the fuel gauge seems stuck... 馃槀馃槀
and I took the tank out to replace the front end.... not to look for fuel leaks..
68AutoBug 路
