peter87 wrote:Hi,
I was driving a 71 super bug today and noticed that when you turn the steering wheel it wouldn't move until i turned in more than half way. I don't know how to really explain it but a normal steering wheel would have the arms sitting diagonally and when i let go they were sitting vertically so the steering wheel has shifted but not the wheels. Any ideas what the problem could be?
Thanks,
Peter
I have just replaced My steering box and the clamp bolts etc
they had all been moving...
including the arm off the steering box.... which has deep grooves..
Not sure about the clamps etc on Super Bug...
but any clamps with bolts thru them, they have fine splines but any movement and the bolt wears...
so renew any bolts in clamps
Are You running a standard steering wheel???
as if that has been loosened... the fine splines in there can let go, but its not normal...
I had to take the fuel tank out to properly see all My stuff..
not sure with a superbug..
certainly sounds dangerous...
although Mine did move move the steering wheel vertical...
also make sure the steering box hasn't come adrift...
