I need one too, managed to snap an arm off when I removed it - it did require a bit of tender loving force.
Hope you're OK.....although they can do wonders these day with micro-surgery.
Pumba ·
Bump
bushed ·
make one from sqr tube steel insert nut and attach a rounded off bolt
cut other end and drill
as per part pic
i will look what I have now the rain has stopped.
Pumba ·
Hi bernie,let me know if you have one,id rather the original than make one.
bushed ·
no luck yet but I will look in my Mercedes stasch now
Pumba wrote:Hi bernie,let me know if you have one,id rather the original than make one.
Pumba ·
No worrys,one will turn up.
Aussie ·
Pumba wrote:No worrys,one will turn up.
I bought a used rod for mine from Vintage Vee dub. Cost me $5. Give them a call.
Pumba ·
I asked boris the other week when i was there but he has none.
Pumba ·
Getting desperate now,i need to get my brakes working.
HappyDaze ·
How much time have you spent on here, looking for the push-rod, Shane?.....and how long would it take to make one? 😁
grumble ·
Shane did you get a pushrod,I saw the early posts and assumed that you had it under control.I am fairly sure there is one on a cluster in the shed,I will check tomorrow. PM if still searching. I could take it to Valla if it is there. Les
Pumba ·
HappyDaze wrote:How much time have you spent on here, looking for the push-rod, Shane?.....and how long would it take to make one? 😁
I know what you mean greg,the body is finally on the pan so i need brakes now.
Pumba ·
grumble wrote:Shane did you get a pushrod,I saw the early posts and assumed that you had it under control.I am fairly sure there is one on a cluster in the shed,I will check tomorrow. PM if still searching. I could take it to Valla if it is there. Les
PM sent
HappyDaze ·
Pity you couldn't fit the push-rod before the body went on.....much easier, particularly for a big bloke.😂 If I had one you could have had it. Somebody help him out.👍
Camo ·
Not sure if it will help, but I'm sure I had two when rebuilding my 61 Beetle. Will have a look asap and try and get a photo up for you.
