Under Dash Query
https://forums.aussieveedubbers.com/threads/97552/under-dash-query
rion20000 ·
Does anyone know where this should be attached to under the dash? My speedo and clock light stopped working, is this related?
cam070 ·
That looks like part of a plug for a speedo bulb to me
DylanTheDubber ·
You Have an L Bug (1303) Don't you?
From Dylan
rion20000 ·
cam070 wrote:That looks like part of a plug for a speedo bulb to me
So I have to plug it into the back of the speedo. I tried but it didn't seem to want to fit...
rion20000 ·
DylanTheDubber wrote:You Have an L Bug (1303) Don't you?
Hi Dylan. I have a TLE T3 Fastback
From Dylan
zocstar ·
check the fuse.
rion20000 wrote:Does anyone know where this should be attached to under the dash? My speedo and clock light stopped working, is this related?
Yes it's very related.
As Cam says thats the speedo back light bulb holder has fallen to bits.
They aren't fused either so if it touched anything metal it probably burned out the headlight switch rheostat.
1970 fasty ·
this happened to me and the other half is still in the speedo.
see if you can pull it out (they are only pushed in) and you will see how they are supposed to fit together.
re crimp the edge with pliers and it will be fine to refit. at worst you may have blown a fuse when it sprung out and may have earthed out.
rion20000 ·
Thanks so much. I thought it was part of the speedo. I'll have a go at the re fit. Thanks guys.
Once they fall apart like that they rarely go back together and stay together.
All air cooled VWs use those style holders, I did find some plastic holders through Hella or Narva many years back but they need an earth wire connected.
The metal ones ground through the speedo body.
