Google is not my friend, so much highly technical info that I have gone into information overload, (not hard for me 馃お)
So here's the question, hoping for a simple answer, keeping in mind that the fuel tank is not a standard Dub tank and it's in the wench.
I have vented the tank from up high in the side of the tank via a tube to the filler neck near the cap, this gives a way for the air to escape from the tank while filling (the filler neck is almost level with the top of the tank and enters the tank via a steel tube about the size of a standard VW filler tube running almost horizontal into the tank) the filler cap is not vented, so when it is installed there is no way for air to enter the tank (esential I would think 馃お) I was thinking that if I drill a small hole, maybe 1-1.5mm, in the filler cap that will overcome the problem, as the cap is not inside the car, it's right at the back exposed to the elements, then I shouldn't get any fuel smell to bother me, but I'm not sure about the merit of what I am intending to do,
What do the gurus think?
Don
donn 路
