Do you Get more Performance on a 1600cc Mild engine from a Small 3 Bolt Flange extractors or Large 3 Bolt Flange?
Or Is There Not much Difference?
From Dylan
hellbugged ·
go the smaller one
Yes
I agree,
You are looking for extraction of gases... Extractors...
so the smaller ones... extract better than just a large pipe...
|LEE
DylanTheDubber ·
Okay Thankyou, Cause I Have a small 2 bolt extractors. I Will run a hotdog muffler with.
From Dylan
sander288 ·
You'll find the pipe size is bigger on the large flange if they are EMPI headers.
The large 3 bolt is 1.5 inch and the small bolt is 1 3/8" which is ALOT better for a mild 1600,
if you went to big you'd find you'll loose some of your bottom end, which with your single carb is where your going to perform best!
