Fuel hose diameter
https://forums.aussieveedubbers.com/threads/97587/fuel-hose-diameter
satori ·
I was just getting fuel tank ready to be installed but have noticed that my fuel out let on the tank is smaller than inlet on the pan. Probably because the tank is a 66 tank and the pan is a 72. Does the later tank outlet fit on a early? also my fuel lines from the carbies are a smaller diameter than the outlet from the back of the pan. What's the go there? Thanks
zocstar ·
It's German??. Mine is like that, it's got metal tubes that reduce the dia and then steps back up. Your right it makes no sence.
Big one is 7mm hose, small is 5mm hose. I carry German in both but presently stock is low on the 7mm
