Item: spring plates to suit 71 lowlight kombi
Item Condition: must be in good condition
Price and price conditions: you tell me
Postcode: 4012
Contact: 0404874097
binner ·
bump ,anyone?
Klaus ·
been going thru my stuff and should have spring plates , do you need complete steering set up ie shaft tube mount for ignition ? as good old lowlights have about 4 different ones
binner ·
^^^^^^^ not the outer toob, just the actual shaft that you bolt the steering wheel and rubber block onto. I have the outer toob and rest of parts but not the actual steering shaft.
Spring plates would be awesome, I'm at a stand still without plates..... 😢
cheers bloke
binner ·
....after some rear axle stubs also ......... so much stuff missing
Klaus ·
got a set of big nut 73 rear hubs complete can do a job lot with other bits say $300
bushed ·
have some axles at Mt Gravatt for u Thurs
binner ·
bump, updated and added to.
Klaus, how much for the springplates only?
cheers Binner
Got the fixed tie rod new if still needed
Klaus ·
$100 posted or can take to valla $80
binner ·
Found 2 items locally .thank you...... just waiting on spring plates and steering shaft....
Klaus, can I call you re: steering shaft, springplates? cheers Ian
