Aussieveedubbers · Bugs
Fuel tank fitments
https://forums.aussieveedubbers.com/threads/97761/fuel-tank-fitments
TCS_58 ·
Hey guys, I haven't seen this topic after a bit of searching so I though I'd just ask. I have a 58 bug with the normal fuel tank but I'm wondering, is it possible to fit a later year tank, the flat type I mean, like the ones found in the supers but with the filler on the top, etc? Reason being, for some reason I prefer the look of this tank (for modifying reasons) and also I'm making as much room as I can for a radiator.
Please help!
flat rat dak dak ·
yes you can fit the later tank in . ive got one in my early model bug.
A superbug tank wont fit but any beam front end car tank will fit, 1500s and later beam bugs had the filler in the 1/4 panel, it wouldn't be hard to fit a 90 degree bend on later tank and run the 1500 style filler under the bonnet.
TCS_58 ·
Cheers guys, one more thing, has anyone ran an internal (if there is room) fuel pump in the later tanks?
Sorry, but a late tank will not fit an early car with an upright tank. The hole is smaller and flat >'60 where the later '60-'67 is sloping fwd. A 60-67 car will accept a 1500 or '68> (all beam cars and not supers)
TCS_58 ·
matberry wrote:Sorry, but a late tank will not fit an early car with an upright tank. The hole is smaller and flat >'60 where the later '60-'67 is sloping fwd. A 60-67 car will accept a 1500 or '68> (all beam cars and not supers)
I have feeling that I'll be replacing the sheetmetal in that area soon anyway, can you just replace it with the 60-67 style to accept the later tank?
Matt Ryan ·
You need to replace forward from the front edge of where the old tank sits. So basically you're replacing the wheel well section.
I have a 60 where some nong tried to make room for a 61-67 tank by cutting metal from the back edge into the firewall only to find out it didn't work. Now I have to replace entire front firewall panel.
Regards,
Matt.
