I left your e-mail address at work.
Here's the pics of the type 4 1.8L heads. A little shabby, but take your pick
:thumb
whoops, got the pics a little out of order. the rest of these heads are at the bottom. The barrel seat has been machined on these.
[Edited on 27-8-2003 by Andy]
Andy ·
And the other set. Valves a little recessed, one helicoil in the missing plug, and a couple of studs missing. They have not been machined down though.
:thumb
[Edited on 26-8-2003 by Andy]
Andy ·
more
Andy ·
more
Andy ·
more
Andy ·
the rest of the first set :o
Andy ·
more
Andy ·
The end is near!!
kombikim ·
geez I dunno which set to pick, just wondering how long the recessed valves would last:alien
Andy ·
How longs a piece of string?
Sitting on the shelf they have indefinite life 😀
kombikim ·
are the spark plugs ok or do I need to get new ones?
Andy ·
Spark plugs are all fine. Put your sump plug where the missing one is, Kombi's will run well on 3 cyl. as I have discovered, don't worry about the leaking oil though, you won't notice it once you drive away :o
sodoyouwannemorwhat???
kombikim ·
OK OK , I am thinking about it
Andy ·
Come on man buy buy buy, don't miss out 😠
kombikim ·
how long have I got to make up my mind which I want before you post them for sale? can I just get one head??🙁
C'mon Kim
2 heads are better than 1!!!
Just wack one of those Subi SVX flat six's in there!!! :bounce
kombikim ·
they are fairly rare, I have been trying to stage a not at fault head-on with an SVX, so i can bid at auction, but this has only resulted in some nasty near misses🙁
Andy ·
Head???? you want head???
Your askin' the wrong bloke mate 😀😀😀
Your welcome to take one, that'll give you a 1.9L type 4. 1.8L on the right, and 2L on the left. :o
kombikim ·
:bounce OK, thanks, I will take the best one, have sent u2u, my problems are nearly over,
I can probably make the 1.8 combustion camber a bit bigger & shave the 2L head a bit, so it won't be so bad
Andy ·
:o:alien:o:bounce:jesus:P:kiss
😎 :thumb
kombikim ·
🙁 no well ok - bit dumb, did not think about using shims to match them, anyway it will get me back on the road
can I go home now?
