2L Cant get the pulley cap off the end of the crank.
https://forums.aussieveedubbers.com/threads/97794/2l-cant-get-the-pulley-cap-off-the-end-of-the-crank
RENNWAGEN ·
I have been pulling down my 2l engine in prep for a rebuild but I can't get the pulley cap off the end of the crank. I've tried tapping it with a plastic hammer and had a small 2 arm puller on it but it won't move. It looks like some one has put permatex on it.
ian.mezz ·
call vintage vw for tech help and parts Ph# (02) 9789-1777
grumble ·
A 3 bolt puller in the fan mount,possibly a little warm and it will pop off. They are on a taper with a key and have to be tight or they destroy the crank.
Normally, undo the three bolts and the fan comes off easily, maybe a wiggle by hand, but generally little or no persuasion required. The hub is usually the only possible issue, at worst a little heat and it jumps off the taper.
RENNWAGEN ·
Got it. Lots of heat, a bent puller and a big plastic mallet. It flew about 4 metres when it popped.
