What could the rattle be??
https://forums.aussieveedubbers.com/threads/97825/what-could-the-rattle-be
RED62E ·
Ok so I bought this 75 kombi. All prettied up and the seller lying about how the rust was cut out and properly done. ANyway thats not an issue. My mechanic has the bus at the moment and he has it running nice but there is a rattle down low. It doesn't afftect power, running or anything and when inside the car you cant hear it. So I am just after opinions as to what it might be seeing as it doesn't seem to affect the running. My young mechanic is not a VW guru either but he isn;t a woose and has a go and all the work on my other cars has been excellant. So suggestion splease of you ahve experienced anything similar. Oh yeah its and 1800 with twin solexs if that means anything. Thanks in advance.
tar76 ·
Not a tappet noise?
ian.mezz ·
old kombis get rattle cam shafts, alternator bearings.
Its uneconomical to pull your engine apart.
Ldog ·
anything its a volkswagon!!!!!!
tar76 ·
What sort of oil are you running in it?
RED62E ·
I have n was runnig rio idea what oil is in it. I took it straight to the mechanic to get it running right. I was thinking it might be a rattly tin bit down below. Wishful thinking I guess.
barls ·
have you checked the ash tray for a set of ear rings
tar76 ·
i'm no engine guru but maybe running the wrong oil?
cam, lifters, cam gear loose, excessive cam gear backlash.......to name a few
greedy53 ·
get the tappets ajusted give it a service than see what happens
good luck
beetleboyjeff ·
Push down on the bottom of the bit of tinware behind the crank pully - I have seen them touch on the back of the pully (especially if the screws are a bit loose, or the tinware is cracked) and they make quite a rattly noise then.
modulus ·
RED62E wrote:I have n was runnig rio idea what oil is in it.
Sorry, I don't know what the rattle is. But get an oil change, filter and strainer change. VW motors depend heavily on oil quality for both lubrication and temperature maintenance.
hth
Lucky Phil ·
It would be a type 4 motor?
They are known to be noisy.
Lucky Phil wrote:It would be a type 4 motor?
RED62E ·
Hey Barls thanks for the hint. I went to Supacheap and bought a tool kit and now have all the bits on the garage floor. No ear rings...bugga.
ian.mezz ·
maybe its a baby car ,
bajachris88 ·
I had a woeful rattle that scared the bajeebuz outta me.
Ended up being the air vane inside the exhaust collector just below the pulley where it goes into 1 pipe. The spot welds had broken off and it was rattling in there. It took me forever to work it out! So much so, i even bloody pulled off the heads thinking it was a dropped seat. I only found out where the rattle was by shifting the exhaust collector once removed and hearing the rattle go off.
I used the 'screwdriver to the ear' trick to find it, and because the noise/vibration must have transmitted through the exhaust into the head, it made me think it was there. Old mechanics often say about the transmission of the sound tricking you. It was one of those 'man i'm so pissed' but relieved moments to realise it was something so simple and on the outside.
