Aussieveedubbers · Busses
Carbs
https://forums.aussieveedubbers.com/threads/97852/carbs
tar76 ·
I'm planing on giving the kombi a bit more punch and would like to change the carbs. I'm staying twin and a choice of 3 types
Weber, kadron or Empi. Iknow the weberes are probably the pick but if i can't find second hand new might be out of my budget. What are the Empi like these days and the 44 kadrons/solex???
tar76 ·
44's, would they big too big for an 1800? I only ever plan on taking it out to a 2L one day.
Stay away from the Empi
My opinion is either Weber or Dellorto
Personally I like Dellorto as they run a larger idle jet and dont block as much
You can get this guy to jet then to what you want
here are some Dellorto 40's
http://www.ebay.com/itm/VW-PORSCHE-DELLORTO-DRLA-40-CARBURETORS-/290736653172?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43b1414374
you could get away with 36's - but for an extra $75 get the 40's
http://www.ebay.com/itm/VW-PORSCHE-DELLORTO-DRLA-36-CARBURETORS-/261064433312?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3cc8a71ea0
otherwise - for Italian IDF40's at $520 grab these
http://www.ebay.com/itm/WEBER-40-IDF-CARBURETORS-/261025907269?pt=Ricambi_e_Accessori_Moto&hash=item3cc65b4245
tar76 ·
Cheers for the link Bizarre they look good!
Are the new empis any better than they were a few years ago?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D47%2D7347
77bay ·
Try Recarb at Kawana Tarin. He's a walking encyclopedia on carbs, has webbers in stock, new and recoed. Prices are good too, I'm putting a single 38mm webber on the 2 litre, brand new complete kit $800.
tar76 ·
77bay wrote:Try Recarb at Kawana Tarin. He's a walking encyclopedia on carbs, has webbers in stock, new and recoed. Prices are good too, I'm putting a single 38mm webber on the 2 litre, brand new complete kit $800.
Crikey dude a single? whats the go there....you know something i don't?
77bay ·
1 screwdriver, 3 jets, 20minutes; or multiple tools, 6 jets and at least an hour to setup right. 1 to tune and service as opposed to twins, and you know me mate, I like to be different.🤓 Good for low down torque, but sacrifices a little at the topend, but it's a bus not a porsche.
tar76 ·
I'll give Recarb a ring as well see what twins he's got. Got to go the twins mate would be like missing one of my balls if i don't 😁
77bay ·
If you've only got one to start with you don't know what you're missing! If it doesn't work Ill step back to twin 40 webers. Recarb has always got parts in stock and last time I was there I think he had a set of reco'd 40 webers for $1000
yarrum ·
Like Bizarre said Dellorto are better. Try looking at euro carb in england you can by a rebuild set of dellorto,s .jetted to suit you needs .New manifolds,and linkages for around 600 pound plus delivery.
77bay ·
From what I've been told, only problem with the delortos is trying to get parts. At least with webers they are pretty eay to come by.
Parts are easily available for both Weber and Dells from Alfa 1750 on ebay. I stock a big range of Weber jets as thats what I see most of. As for Recarb, speak to some of my customers and thay can give you a referral, I've got quite a few that can share thier experiences 😂, PM or phone me for details. Tarin, I'd go 40mm IDF's or Dells if you plan on 2.0 litre, keep well away from HPMX IMO, yes you might get them going ok......
tar76 ·
HPMX really try to push there better than weber.
I had the old verision on my last panel and had a lot of idling dramas. Anyone else find this with these or have they turned things around like they reckon?
spearsy ·
Unless you have other work done on your engine the only real noticeable difference will be in your wallet with a larger fuel bill.I know too many people that upgraded carbs only to go back to a set of well rebuilt Solexs.When tuned properly they run very well.
tar76 ·
spearsy wrote:Unless you have other work done on your engine the only real noticeable difference will be in your wallet with a larger fuel bill.I know too many people that upgraded carbs only to go back to a set of well rebuilt Solexs.When tuned properly they run very well.
thast why i'm not going too big and just going with a set of 36 idf's
Klaus ·
ran a rebuilt set of 40 webers on a stock but well looked after 2ltr and fuel usage was the same as stock and drivability was smoother, its how you set them up is the key , dyno tuning helps alot , go with dual kadrons a complete new kit with electric chokes can be had for about 800
