Why buy Dynamat?
https://forums.aussieveedubbers.com/threads/97878/why-buy-dynamat
psimitar 路
So if anyone is interested I have done a price analysis for sound deadeners available in Oz.
Most are sold thro Ebay except for Resomat that is sold direct.
So the prices are for the largest bulk pack each vendor sells but unlike Dynamat most of the others aren't that much cheaper per square metre from the smaller sizes each vendor sells.
Starting at lowest we have
Solavis $49.71
dBKill $51.03
Car Builders $55.56
Resomat $56.00
Sound Deadener $57.14
Dynamat $69.76
As you can plainly see the Dynamat is $12 more expensive than the second most expensive and $20 more expensive than the cheapest and this is per metre squared pricings.
If you all wish to continue using this over priced American crap then go ahead but if you do some research you'll see that most of this stuff does as good a job as Dynamat and yet are Aussie made. So 4 good reasons to buy Oz are just as good a quality, does the same job, saves you money and keeps the money in Oz. 馃榾
DubLeg 路
I'm all for keeping money in Australia. 馃檪
68BUS 路
Thanks for doing the research for us.
Good to know what other brands are out there.
There is also Honey if you want to go really cheap...
http://news.ninemsn.com.au/national/8500006/handyman-finds-honey-filled-ceiling
DakDak67 路
Why say this , "If you all wish to continue using this over priced American crap then go ahead" what's your problem with Dynamat? have you used it? or don't you like it because it's expensive? just wondering.
waltermitty 路
Pretty sure none of these are Aussie made, I dont know about the dbKill. Mitchell
LUFTMEISTER 路
Sq mtr rate maybe correct but what about weight per mtr? The other stuff maybe half as thick so the value soon decreases. My2c
shaven 路
LUFTMEISTER wrote:Sq mtr rate maybe correct but what about weight per mtr? The other stuff maybe half as thick so the value soon decreases. My2c
also agree with this. the thickness of Dynamat... is far greater then some other brands ive seen. this also tells me its alot better then other brands. you get what you pay for i guess or what your willing to pay馃お
psimitar ... as you have given your valueable opinion... have you used any of the others?
also Australian made... pretty sure thats not totally correct. love to be proven wrong & dollars left here in Oz are far better!
vwpizza 路
I have used Dynamat in my Kombi s/c and I am very happy with the results, I used another product in my Oval (sorry not sure of brand) and it did not stick very well at all. I think I'll stick with using the better quality product,my 2 cents worth..cheers Dino
68AutoBug 路
I didn't know about the aussie ones..
Main reason I steered clear of dynamat is the weight...
I do realise it does an excellent job..
in a 1200 kombi... lot of extra weight to carry around.. lol
psimitar wrote:So if anyone is interested I have done a price analysis for sound deadeners available in Oz.
Solavis $49.71
dBKill $51.03
Car Builders $55.56
Resomat $56.00
Dynamat $69.76
shaven 路
68AutoBug wrote:I didn't know about the aussie ones..
Solavis $49.71
dBKill $51.03
Car Builders $55.56
Resomat $56.00
Dynamat $69.76
put i decent engine in it馃槀馃槝
gerggl 路
In all fairness unless you have tried all of the brands you research then it is not a realistic piece of research - give Choice magazine a call at least they test their products before bagging them out!
BugsyMalone 路
I used Car Builders in my '83 Suzuki Hatch, cant compare the difference of sound between this and any other, but it was far cheaper, easy to apply and has made my hatch far quieter. So I'm happy with the outcome
BugsyMalone 路
More
bajachris88 路
remember cost effectiveness is in the proper use of the material too.
You don't have to cover an entire panel to get the 'resonance dampening' effect.
Covering the entire panel doesn't make it any better, it becomes useless extra weight and initial cost when you exceed the usual recommended 25% required covering.
Here's my sound deadener before/after test on my baja using generic butyl matting (butyl matting, being what dynamat is)
Before:
After:
psimitar 路
Guy in the USA did his own independant testing and from 6 years of testing has finally started to manufacture his own reasonably priced sound deadening and absorbing materials. His findings showed that Dynamat was pretty run of the mill compared to what was around back then. Heck if we could buy his stuff over it and it works like he says it does then the cost slays Dynamat as well as most other good brand names.
I've been around cars long enough and in other parts of the world to know that Dynamat sells a majority of it's product from popularity stakes IMO and have tried Brown Bread, Noisekiller, AT and Dyna-kak.
For everyday motoring needs most of the products I looked at will do a good enough job that most ears wouldn't know the difference. Even in Sound-offs Dynamat has been beaten by AT and Brown Bread in the past.
I always do my research before opening my mouth and it's not just weight but it's acoustic dampening factor that is dependant on not just weight but the products composition as these products turn vibrational energy into heat and the better they do this the more dB are absorbed. Not all these products give acoustic or dB losses to back up their claims. If you look at Solavis it has a greater acoustic loss factor than Dynamat extreme at 20 and 30 degrees C and most the rest of the temp range too.
So, Yes, I have a problem with anything that seems to sell by popularity but at the end of the day I am just trying to open peoples eyes and not just believe the crap some sales person tells them.
The stuff is more than likely made in China but so long as it's made to the specs of the Aussie company then buy from the company that has done it's own research and not jump on the Dynamat/Yankie bandwagon 馃檪
Governor 路
http://www.raamaudio.com/?fullSite=1
I have usd this after researching all brands, they have an agent in Singapore and including shipping it still worked out cheaper than the others and in tests its better than Dynamat
psimitar 路
gerggl wrote:In all fairness unless you have tried all of the brands you research then it is not a realistic piece of research - give Choice magazine a call at least they test their products before bagging them out!
In all fairness I do try things and do my research before bagging products out so 馃槒
68AutoBug 路
I think it was good info seeing I had never ever heard of any of them apart from dynamat..
and a price comparision... Good..
not saying it has to be exactly correct.
but most items regardless, can be found at different prices..
but at least a comparision...
and all this info was found and written on here..
Good Job..
68AutoBug 路
Choice isn't free...
I have seen how they test products - fridges - washing machines etc.. someone would have to pay for all the tests and testing a noise deadner etc wouldn't be cheap...
so, this isn't an option....
I'm just looking for a bit of knowledge..
and this thread is working great...
also depends on what You want the product for..
AUDIO in the car or stopping noise from outside the car
vibration etc... Most of Us, will probably only do this to Our VW once...
68AutoBug 路
Black64 wrote:http://www.raamaudio.com/?fullSite=1
I have used this after researching all brands, they have an agent in Singapore and including shipping it still worked out cheaper than the others and in tests its better than Dynamat
So, do you live in Singapore...??
No location in Your info..
Governor 路
No, they ship it from Singapore to Aus and its still cheaper than Dynamat
psimitar 路
68AutoBug wrote:I think it was good info seeing I had never ever heard of any of them apart from dynamat..
Good Job..
Cheers Lee 馃榾
This was my intention to give people the info to possibly make a different choice.
Some of those that make the less pleasant remarks either sell Dynamat or have jumped on it's bandwagon so unless they want to do their research before having a go they should zip it 馃檪
psimitar 路
Black64 wrote:No, they ship it from Singapore to Aus and its still cheaper than Dynamat
I looked at this stuff after you posted the link and looks OK. It has a fairly thick aluminium layer and 1.5mm thick butyl rubber constraining layer so bit thinner than Dynamat Extreme but not bad. The one thing they don't give are dB or acoustic loss factor. It'll still do a pretty good job but know these measurements lets you know how good it performs. I'm gonna email them and ask cos looks cheaper than the others I've mentioned.
Governor 路
There was a site about 3 years ago that compaired all the different types and this came out as exactly the same as Dynamat for noise reduction, the things it beat it on was it was cheaper and it had a better adhesion for sticking to roofs(didnt fall down as quick).
I have searched for that site and i cannot find it again, I ordered a roll from them 2 years ago and it was posted from their agent in Singapore and it still worked out a hell of a lot cheaper than the others.
bajachris88 路
all your answers: sounddeadenershowdown.com
remember, all butyl matting is a resonance damper, not a sound deadener.
Governor 路
That was the original site but 3 years ago they were recommending RAAMat, now hes selling his own stuff so its not really a showdown anymore
psimitar 路
SO RAAMAX was as good as dynamat aye. Good thing to know as they don't list the loss factor on their website. Think I may give this stuff a go then if your sure it gave the same results 馃檪
Shame he closed down the original site so he can sell his own stuff now. It was the only independant test done of these materials.
And Chris, I think you'll find the deadener is a dampener. Bitumen and Butyl work in a similar fashion when closely adhered to body panels. All they do is absorb the sound frequencies and turn them into heat. If you don't adhere them to the panel properly then it don't work so well.
Glad peps have found this helpful tho. Who says one man can't change the world 馃檪 Next is to get rid of Gillard and Abbott 馃榾
bajachris88 路
psimitar wrote:Next is to get rid of Gillard and Abbott 馃榾
I believe in you 馃憤 馃槀
Governor 路
I found RAAMat worked, now I bought my roll over 2 years ago from them and I dont know what their prices are like now.
If you google raamat v dynamat you will see a number of people have found it does the same job just cheaper.
The reason lots of shops stock Dynamat is the normal buyers have only heard of dynamat and dont know there are alternatives , the sellers also only stock that because they are making a tidy profit from it?
Also as you dont know me from Adam its always best to do some research and confirm or deny any recommendations.
BugsyMalone 路
bajachris88 wrote:remember cost effectiveness is in the proper use of the material too.
Before:
After:
Yes, I didnt need to cover every panel, but it has stopped the rattles 馃憤
Mr Bubble Head 路
I've just done the rear quarter panels and doors of the Oval with one sheet of the 3M sound deadner which I brought from 'The Body Shop" paint suppliers. It worked out to be $38 and has done the trick really well.
All I wanted is to stop the drumming noise caused by road noise not cover every inch of panel. I cleaned then heated the door and the mat then peeled off the adhiesive backing paper and applied with a small rubber roller.
Even using just one piece approx 1200 x 900 the weight is very heavy I'm happy with using the standard tar mats then rubber mats on the floor and my trimmer used some trimmers wading behind the rear seat engine fire wall before laying down the carpet.
psimitar 路
The RAAMmat is looking pretty good after reading a fair few articles and forums. Funny also, that a guy that used to work for Dynamat only used it whilst he worked there due to an 85% employee discount. He said the stuff was WAY over priced otherwise and just as good as most other good names.
As for covering every square inch. Nope, not necessary. Flat panels need at most 50% coverage but really 25% should do the trick. Floorpans it's a good idea to do the majority of the panel to deaden the low frequency of road noise. contoured panels inheritantly have less vibration due to their structure.
Anyhow, easiest thing is to pop in 25% coverage and if you think it ain't enough pop some more in but remember people that this stuff deadens panel vibration and does little to absorb noise. For this you need closed cell foam or a correctly formulated carpet felt but closed cell foam is generally better. 馃槈
vlad01 路
Mr Bubble Head wrote:I've just done the rear quarter panels and doors of the Oval with one sheet of the 3M sound deadner which I brought from 'The Body Shop" paint suppliers. It worked out to be $38 and has done the trick really well.
is that the one in the pic? its black yeah?
Lucky Phil 路
My research was limited to asking around and quizzing a few people who use it.
They all said they would rather pay the extra for Dynamat.
The RAAMmat seems okay though.
68AutoBug 路
WOW that is one very nice interior... EXCELLENT...
that's what I don't like is the weight...
psimitar 路
Cheers Chris 馃榾
Guarantee I'd do a better job and talk straight with no need to bad mouth the opposition cos my actions spoke louder than their words 馃檪
psimitar 路
Lucky Phil wrote:My research was limited to asking around and quizzing a few people who use it.
Until recent years there has been little choice in Oz and the yanks got in early with their named brand. As already said Dynamat works just fine but for the price it lives off it's popularity and isn't worth what you pay for it.
So long as you're happy then I'm glad you like the effects of Dynamat. For others out there and especially these days it pays to shop around 馃槈
