F/S ball joint front wheel bearings (German) SOLD
https://forums.aussieveedubbers.com/threads/97885/fs-ball-joint-front-wheel-bearings-german-sold
smithy68 ·
Hi Have for sale brand new in boxes wheel bearing kits to do both front wheels on a VW bug with ball joint front end, so 68 onwards.
German brand as shown in picture.
$40 dollars including post Aus wide
Contact: PM, or email, markandnat@internode.on.net
Barty63 ·
Will these fit a ‘73 standard with front drums brakes?
if yes then i will take them.
smithy68 ·
Yes they will
LATE BEETLES WITH BALL JOINT FRONT END DON'T HAVE LOCK NUTS WITH SPLIT PINS..
they would be for beetles before 1967..
and with drum brakes..
smithy68 ·
Maybe someone who knows can tell me what they are for the box says for 65 to 79 , I got them from just kampers.
Give us part numbers. There are two different model front wheel bearings for ball joint front ends
11CAB ·
The part number is on the box...... 191 598 625
That sounds bad, because its a rear wheel bearing kit for a Golf......
However, it contains the bearings 311 405 625F & 311 405 645 which are the front wheel bearings for a balljoint front end
smithy68 ·
The bigger bearings number is lm45410 p6 the smaller one is lm11710 p6
flare ·
I grab off ya!
smithy68 wrote:Maybe someone who knows can tell me what they are for the box says for 65 to 79 , I got them from just kampers.
German 65 models may have been different to aussie >68
models..
disc brakes weren't out in 65 AFAIK..
So maybe for USA SPEC 65- to 79 inclusive
as NO USA beetles ever had disc brakes....
so they may be for drum brakes ball joint front end??
which should fit the 73 non super beetles
11CAB wrote:The part number is on the box...... 191 598 625
rear wheels on golfs probably use them
common tapered bearings..
as golfs may have special heavy duty bearings for the front drive wheels
many front wheel drive cars do..
Yep, Golf rear kit, throw away the lock nut and pin and it becomes a 68> disc brake beetle front kit
69bug ·
If it a 68 onwards front set i will take them
Pm your pay pal address !
smithy68 ·
Still for sale
cam070 ·
I'll take them. Pm me your payment details
smithy68 ·
Sold
