Aussieveedubbers 路 Busses
Noise
https://forums.aussieveedubbers.com/threads/98003/noise
tar76 路
Driving my bus tonight, i turned the stereo down and i could here a slight whine type noise. Seemed worse when i was just cruising but pretty much vanished when i put my foot down?
It 's there when i'm on about 40-60kms and when i get up to speed 80-100 don't hear it. Manily comes from the passenger side rear.
CV's make more of a clacking sound when stuffed?
Man this is all i need a week and a bit out of Valla 馃檯
zocstar 路
Just turn the stereo back up.
CVs are the clacking and under load (turning).
tar76 路
zocstar wrote:Just turn the stereo back up.
Might just because i haven't driven the bus for awhile and am use to driving the falcon work ute?
thats it mate turn the music up and no noise馃檪
polarbus93 路
id say just dont slow down sit at above 80 at all time lol
bajachris88 路
be sure your tranny fluid is at appropriate levels. If so, keep on trucking 馃榾
MISS VDUB 路
Ask Dr Berry!
binner 路
tar76 wrote:Driving my bus tonight, i turned the stereo down and i could here a slight whine type noise. Seemed worse when i was just cruising but pretty much vanished when i put my foot down?
usually when I hear a slight whine it is the missus. I just turn the radio back up to 11 & smile. 馃槀
Bob down 路
you are probly just used to driving the sterile ford in which you can barely hear the engine running maybe?
matberry 路
Plenty of good advice above.
Possible rear wheel bearing.......
tar76 路
matberry wrote:Plenty of good advice above.
Man i hope your wrong for once Matt and it's just me hearing things 馃檨
Scottkombi 路
I have a similar problem in my early bay that is a whine type noise @ 60kph / 40Mph and I narrowed it down (after replacing all wheel bearings) to the speedo cable drive in the front left wheel.
For some weird reason is develops a humm @ 40mph??
After all that bearing replacement - I gave up - getting slowly quieter again over time.
Strange creatures these vehicles.
tar76 路
Yeah took it for a drive this arvo and might be just me, but like you Scottkombi probably get more use to over time.
another question where the accelarator cable connects to the bracket that goes through the floor (in cab) anyone have a pic. I'm replacing my throttle linkage that connects to peddle, and when i removed the old one the cable came loose from bracket. Just looks like the cable goes through bracket hole,but i'm not sure what stops it from poping back out ( the bend in the end)?
grumble 路
The Z in the cable goes through the hole and the weight of the accelerator spring keeps it in place.
tar76 路
grumble wrote:The Z in the cable goes through the hole and the weight of the accelerator spring keeps it in place.
cheers man thats what i thought but wasn't fully sure.
