booge wrote:Hi everyone I have a 67 bug almost finished resto had it booked in for blue slip yesterday only the motor wont run properly I have changed plugs and leads rebuilt carby ajusted timing and points new condensor but sill no joy she idles a bit rough bit under load verry unhappy miss fires no power any ideas?
When You say no power...
Can it be driven? I could never drive Mine when restoring it, but it started and idled perfectly... the accelerator pump on the carby was block by old fuel... [it still is, in the shed]
but Mine idled perfectly..
what about the distributor cap? wipe inside with petrol or metho or WD40 etc..
also check the rotor inside the dizzy cap..
they have a resistor in them to stop radio interference and they can burn out... not common but does happen..
also wipe it all over with petrol etc too..
make sure the coil is connected + to POWER
- to distributor as an engine may go even connected wrong way around...
All spark plug coil leads should be checked with an ohm meter
unless they are the original wire type..
as silicone etc can open circuit easily...
My new lead to the coil broke inside the lead first time I pulled it off the coil... sounds like a coil or dizzy problem..
is the engine earthed??? there should be a lead on the gearbox, other wise the power has to find its own way thru the gearbox etc.. engine & gearbox are on rubber mounts..
Better to try everything Yourself... unless You have a good VW air cooled mechanic nearby...
stay away from any other mechanics unless they are old and retired.. lol
