Piston Rings 1600 twin port (part number)
https://forums.aussieveedubbers.com/threads/98079/piston-rings-1600-twin-port-part-number
Pfeffernuss ·
Hello,
I'm rebuilding my 1600 twin port 71 engine. Engine prefix 'T'. I have a stock 1600. The cyl barrels are honed to the stock size, according to the Haynes manual.
Having measured the gap with the piston within the cyl barrel, it appears that i have worn rings. And seeing that I have come this far, may as well replace them.
I am struggling to find the correct part number for the rings.
Should I get genuine, or aftermarket?
Can you recommend any Australian suppliers?
Thanks!!
Pfeffernuss ·
Maybe this is the ticket?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D311%2D198%2D169%2DA
Fastie ·
Call Mick motors - piston and barrel kit includes everything for $200
You might want to check the condition of bearings etc too
Pfeffernuss ·
Hi,
Managed to source a set. genuine 85.5 piston rings.
thanks to Rod Penrose's contacts
i'm not gonna split the crank case this time - just see how we go.
i have 3 1600 engines now, so i can slipt the crankcase on one of the other ones and get it schmick while i run around with the other engine.
Pfeffernuss ·
Ok, got the 1600 piston rings.
cofap rings. Made in Brazil. Made by MAHLE
CA.2297 STD
AJ0702297-00CA0422/72/82
85.50
