Hello,
Having just got the 72 VW 1302s last week (after 3 years apart), I have been spending some time looking at and under her. Just had the motor rebuilt, replacing the block and the innards, and only done a couple hundred miles.
I noticed on the Driver's side of the motor, that the push tubes and cooling fins are covered in soot, as if from the exhaust. A small hole in the tinware has also left soot on the inside of the bonnet/boot lid above it. The passenger side is fine.
I cannot find a leak in the exhaust manifold flange area. Is it possible there's a head issue? I'm hoping it's something small, but i'm a little concerned. I will pull the tin off after work tomorrow and have a look properly.
Any likely causes I should be mindful of?
Oh and coasting down a hill with nil throttle this morning, I thought I heard a pop/backfire, but a one off. Driven gently... She seems to drive well otherwise.
Thanks.
Joshua.
joshuah ·
