FS: Weber ICT 34mm dual carb kit - type 4/bus
https://forums.aussieveedubbers.com/threads/98195/fs-weber-ict-34mm-dual-carb-kit-type-4bus
forry2000 ·
I have for sale a dual Weber ICT 34mm carb kit, which i purchased from Just Kampers approx 1 month ago. This is a near new kit that has been jetted for my 1800/2L bus. (many hours of road running to get these jetted correctly - just came back from Valla, these carbs ran beautifully).
The carbs run extremely well, and my only reason for selling them is to go a bigger Weber IDFs.
These are genuine Webers, made in spain. The kit includes, alloy crossbar linkage and heim joints, EMPI manfolds, chrome air cleaners with pre-installed oil/fuel breather, and a pair of newRedline Weber rebuild kits purchased from Aircooled.net in the USA (still sealed).
They are currently bolted to a set of stock inlet manifolds, which saves stuffing around with brake booster connections, and utlises the stock elbow connections, and stock carby return spring and allows you to just bolt in place (or you can use the inlet manfolds that come with the kit).
Price: $400 ono
Phone: 0410566104
