vwo60 wrote:If the serpintine belt is subjected to the same amount of mud it will probaly wear as well, why not fit a cover over the belt so it is not subjected to the wear issue, the other problem will be mud getting into the idler puller bearing, from what i can find out the bearings in a lot of the idlers are very average, i just rebuilt my alternator and had a problem getting quality bearings, not some non discript chineese rubbish that is currently available, as far as i can see it is just another point of failure that will get over looked until it fails in the middle of noware.
The belt won't wear as badly because on a V belt the edges wear off and they soon lose tension. Whereas a muiltrib runs on the bottom edge on on the sides of the belt. Plus the tensioner will keep the belt tught anyway.
You make a good point about the idler pulley bearing. I have no intention of buying a cheap kit so I hope that good quality parts will be present. As for breaking in the middleof no where, I always carry spares in the car, and a spare idler and belt won't be an exception. You're mad not too in cars this old, especially the kms and flogging that I give mine.
I emailed both of the companies that Uber Kafer mentioned above, so far no replies.
Smiley
馃檪
