I'm considering buying an air compressor primarily for some paint work I will hopefully use it to spray my kombi.
As it will recieve little use after that I dont want to spend a fortune.
I saw one today on special at Kmart for $150 with a 15m hose and tyre pressure guage thingy it is 2hp with a 24 litre tank - will it be able to do the job ?
The other one I have looked at is supercheap at $199 for 2.5hp and 40 litre will it be a big differance?
Andy 路
Try and find one of the custom VW heads Queensland rail used to have. Then you can turn your spare beetle motor into a compressor.
2 Cylinders for the compressor and 2 to run it. 馃榾
fatboy 路
Cheers andy- not really practical for me though. 馃榾
NE1 ?
Craig Torrens 路
the bigger tank would be better for spraying...........I think !
from what i discovered stay away from the cheap ones as you'll run out of air after a couple of passes and then have to wait for yonks to go again.
if you are only useing it to spray the kombi go hire a decent unit for a week, will work out much cheaper
Seriously_Individual 路
i brought an arlec compressor from kmart awhile ago. Its pretty good, i brought the spray gun from kmart aswell. They do a pretty good job, just have to use low pressure.
fatboy 路
As in a low pressure spray gun ?
11CAB 路
Hey Chris........does this been your not going for the Rat Look with your kombi anymore and you'll actually paint it?? 馃榾馃榾馃榾
yes it is a low pressure gun... i think i cost $60 around about...
i have painted a new sliding door, and the door that i brought off you Graham... i'm getting there slowly.
Craig Torrens 路
"Little Beaver" works well with enamel !!
As long as you have plenty of wet and Dry 馃榾
VWCOOL 路
...and buffing compound
KruizinKombi 路
Steve, I've got an eager beaver that you can borrow, if you haven't already bought a compressor. It should cope with what you have in mind. 馃槈
