So i though I'd just put up some photo's of how I've used a microswitch to make a vac operated 78 T2's windscreen washer into an electric washer.
Two wires to solder to the common terminal of the switch and to the NO (normally open) terminal and heatshrink the NC terminal.
Run one to a switched live fuse in the fusebox and the other to the positive term of the electric pump you've bought to plumb into the reservoir down by the pedals. Negative pump term goes to chassis ground (zero volts).
Maybe use bullet connectors in the steering column so you can remove the switchgear easily in the future.
Hey presto, you now have electric washer jets 馃檪
psimitar 路
