Type 3 Fuel injection - SOLD
https://forums.aussieveedubbers.com/threads/98444/type-3-fuel-injection-sold
Fastie ·
Sick of tuning your twin carbs as they go out of balance? Maybe you own a TLE and a PO replaced with carbs.. and want to go back. Do you owna notchback that never came with injection but dreamed it would.
Take the hassle out and replace with economical and smooth injection.
Just removed this injection from my TLE - was running nice and smooth until my engine gave up the ghost.
I'm replacing with larger engine so that is only reason I am selling this.
I have labeled each piece of the loom to make it easy for re-install.
You get;
Injectors
injector blocks - one needs replacing
AAR
fuel regulator
Plenum
throttle body
loom
Only piece missing is the fuel pump - just buy a universal pump and connect the grounding wire from ECU and you are all go.
This could possibly fit a beetle too - but unsure if fan shroud/tinware would get in the way or not??
Could be what you are looking for with the upcoming megasquirt project.
Please note - this will ONLY work with 1600 and stock internals, because of ECU. If you are running megasquirt, no problems. I have heard that 914 injectors can be used for larger piston/barrels such as 1641 or 1776 but I can't confirm this.
$400
Please PM me if interested.
Staf
Vic 3065
Fastie ·
Now on ebay;
http://www.ebay.com.au/itm/221110065244?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_500wt_1156
there was someone on here a little while ago wanting this set up
Fastie ·
Final day on da bay
Fastie ·
Sold
