1976 Mk1 Golf Swallowtail 1.8L K-jet turbo
https://forums.aussieveedubbers.com/threads/98449/1976-mk1-golf-swallowtail-18l-k-jet-turbo
motha ·
Moving on……
Genuine 4/1976 Mk1 Golf Swallowtail
1.8L K-Jet turbo
Original registration IMS 016
This is currently my daily driver, travelling 600+km a week.
First & currently still the fastest Mk1 in Aust.
12.99@107mph with a poor 60ft!
Body looks & presents itself in good condition, but in reality, its in “Fair” Rusty condition where you can’t really see it. Supplying a spare very straight & dry shell from central NSW
Interior is “Immaculate”. Very hard to find a cloth interior in this condition. Also has Diesel front sound deadening.
Supplying a new spare plain white headliner in its bag.
Can read about the cars initial build up with here
http://forums.aussieveedubbers.com/viewtopic.php?tid=72149
Your really buying this car for the complete running gear, suspension, brakes & interior, which would be transferred across to a nice Mk1 shell.
Will separate running gear, but prefer to sell complete, as a Jump-in-&- drive going concern.
No RWC.
Reg. till May 2013
Geelong, VIC
$8000 in as is “Current” condition
Can test drive (Definitely No tyre kickers!!!!) Have no time at all for this.
Will also throw in the custom widened 13” stock rims with the brand new, never used M&H DOT street/drag tyre
Running gear is as follows. All the hard work, testing & development is all done. Advertised separately if parting out.
Can read about the build up, testing & development here
http://forums.aussieveedubbers.com/viewtopic.php?tid=92145
Just had a service. Next service is a Major incl. oil, oil filter, fuel filter, spark plugs, cambelt, tensioner, airfilter clean
1.8L (Still a strong engine, doesn't use any oil, but really requires a full rebuild & machine incl the cyl. head)
Ported cyl. head with stock sized valves.
Ported modified G60 intake manifold & weber/redline throttle body adapter
270 Autotech cam,
HD Autotech valve springs
Autotech Adjustable Cam gear & Intermediate gear
1.8T Rods with ARP rod studs/nuts
Stock pistons, rings, bearings
ARP Main studs, head studs
G60 steel headgasket
ATP log style cast iron ported exhaust manifold
T3/4 Garrett turbo (oil cooled only) .48A/R exhaust housing Ported turbine & compressor housings
Complete good working order K-jet gear, K&N air filter, Warm up Regulator, Fuel Accumulator, cold start valves, Hobb’s switch etc, all steel fuel pipes to & from tank
Diesel fuel tank.
AN fittings & braided hoses throughout, Autometer fuel pressure gauge/K-Jet Pressure tester tap setup
MSD 6 BTM (Boost Timing Master – Boost retard system) ignition system, MSD Blaster Ignition Coil, with MSD 3 Step module (for building boost at the start line), custom MSD ignition leads, lead separators etc.
Custom engine wiring loom & custom Battery cables
Refurbished Diesel Alternator
Galant VR4 Intercooler
Tial Black “Recirc” Blow off valve. – Optional Tial “Silver” open atmos. BOV
Engine breather hose & oil catch can. (Moroso “Billet” catch can)
3” Exhaust dump pipe with oxy. sensor fitting.
Complete 2.5" custom exhaust system.
Diesel starter motor
Current 5spd tall ratio gearbox (sits on 2600-2700 @ 100km/h), really requires a reverse idler gear. (noisey as hell in reverse only, but I’ll supply a old style hardened steel type). Still very drivable/usable
Brass bushed short shifter linkage (These are modified to clear the turbo compressor housing)
HD 210mm clutch
Driveshafts to suit 100mm inner CV joints with new inner & outer CV joints fitted
Spare drag Diesel 4spd with ARP ring gear bolt kit, welded diff centre
Spec “Drag” 210mm Clutch kit & lightened flywheel (Matched setup)
Mk2 Brake Booster & Master cyl. setup with all the engine bay brake lines & hidden brake lines inside the car incl. Scirocco 16V rear disc Proportioning valves located under the carpet.
Braided ADR -7 Brake hoses
Electric Brake pedal switch conversion
Rear disc conversion incl. Scirocco 16V brake cables
ATE Powerdiscs fitted all round – new on the front, rear have virtually no wear
ATE OEM Brake pads – new on the front, rear have virtually no wear
New front wheel bearings & hubs
KW V3 full adjustable suspension incl. Compression, bump & height adjustable – Perfect for drag/circuit racing (These cost $2828 alone when purchased!)
ABD 25mm front hollow lightweight anti-roll bar (Not currently fitted)
ABD 28mm rear hollow lightweight anti-roll bar (Currently fitted)
New tie rods & tie rod ends (LH adjustable tie-rod adjustable conversion)
Later model 17-19mm? lower balljoints & control arms (Diesel spec)
For an extra cost...
Can also supply a "Complete" Window, door weather seal kit to suit the "Stainless chrome window surround triming". Also incl. new chrome from & rear window seal beading & NOS "Volkswagen" & "GolfLS" script badging.
This is a complete kit! Inner & out scraper seals, 1/4 glass seals, door frame seals, boot seal etc etc.
This alone took me 2+ years to source one bit here & another there, as there is not one manufacturer that does a complete kit & alot of it is only made in runs bits & pieces at a time.
The list goes on & on with all the modifications, development, wiring modifications etc. etc. in building a car like this, to not only build strong, but also reliable enough to be a long distance daily driver, make good power (insane to others who've never experienced it), great fuel ecomony etc.
Anyone who’s been for a drive or driven this, can attest to how its built & drives.
All thats really to do, is prepare, paint & rebuild the other shell with the complete running gear, all the mint interior, new seal kit & you have a complete inner & outer restoration with grunt like no other Mk1 Golf in OZ!
PM for more details if required.
Tim
