Will fit Karmann Ghia or Type 3 Front passenger side, I no longer need it.
$50 obo
Located 4160 South Baysie of Brisbane
David
0434 58 22 64
Calcool ·
Hi Guys,
I have a Fram Oil Filter and Mechanial Oil Pressure guage for sale $150 ono and its yours. They are available new thru Porsche but over a $1000 I have been quoted.
As in the pics it comes with its mounting clamp, some oil lines and a mechanical oil pressure guage, ie you would need to run an oil line to the front of the car for it to work. It was plumbed thru the oil pressure adaptor as in the pics and tapped back into the case for full flow oil cleaning. You will have to make up oil lines to mount it as you wish in your engine bay depending on engine and model. Repro stickers are avaialbe in the states if you wanted to do a complete resto.
Was fitted to my old 54 Beetle and did not leak.
Located South Baysdie of Brisbane 4160.
David
0434 58 22 64
Calcool ·
Hi Guys,
I bought the drivers side opening front door quarter vent window when I was in the UK years ago as it was in really good condition, but I have since found another pair and no longer need this one (I bet now I will break my drivers side and need it) So keep the driver cool with this one or hunt down a passenger side. $95 and its yours.
Front an rear Lowlight Chrome Bumpers off my 69 they are straight and solid, they do not come with brackets though I may have some I can dig out I do have the chrome bolts though, There is one spot of rust on the top of the front bar and on the pass front step as in the pics and the rear bar is a bit dull, fine for your daily driver or rat them up for your rat! $275 for the pair.
Located South Bayside of Brisbane 4160
David
0434 58 22 64
Calcool ·
Bumpers
Calcool ·
Steps
bushed ·
will it fit hilights 73 or 74 also Cal?? and have u a rubber surround?
how diffr is KG pan from a super bug anyone pls
am interested in both B
Calcool ·
Hi Bushed,
The Quarter vent will fit all Kombis 68 to 79, I do not have a rubber but they are available new.
The Karmann Ghia Pan is wider than the Superbug pan but you could trim it down to fit a superbug if required.
Willing to do a deal on both.
David
lovinbronx ·
Calcool wrote:Hi Guys,
