Aussieveedubbers 路 Tech Talk
boost sensitive reg carby turbo
https://forums.aussieveedubbers.com/threads/98488/boost-sensitive-reg-carby-turbo
bugzla 路
hey guys what sort of boost refrence fuel reg do you use or know of can be used for a carby setup and any help with line and pump choice before i buy the wrong one 馃檪
ian.mezz 路
we have stock holley reg and pump,
and a
"TP" or Turbo Prep carbs. Street drivers, sand toys or drag beast.
We take new carbs and set them up for all out power making turbo use.
But the best part is if you want the best carb to drive on you cant beat OUR "TP" Holley's!
Smooth power and easy adjustments!
Each carb comes with "Turbo Adjust-A-Jet."
With this neat main block you no longer have to change main jets.
No more opening of the float bowl and spilling all that fuel.
Just turn the main screw that is located on the top of your carb to make your combo run more rich or lean!
Its that easy to adjust the size of your main jet!
You will not carry jets any more
bajachris88 路
cgbmotorsport.net sells all the second hand turbo gear for the Renault 5 Gt's, including the stock turbo prepped blow through carbs for $165 AUD (depending on exchange rate), also includes the stock fuel pumps and boost dependant fuel pressure regulators for fairly reasonable prices.
IF you want new, you could also go on ebay for rising rate fuel regulator or boost fuel regulator etc. This new one is $39 from ebay http://www.ebay.com.au/itm/FUEL-PRESSURE-REGULATOR-PK7EG-RISING-RATE-EFI-TURBO-UNDER-18-LBS-BOOST-NEW-/221065279865?pt=AU_Car_Parts_Accessories&hash=item3378847979
bugzla 路
bajachris i think its only efi
bugzla 路
ian is it only holley that you do and have you blown through them not just draw through
psimitar 路
depending on the size of engine the Renault 5GT Turbo carb, fuel pump and turbo would be a simple bolt on exercise with a bit of fabrication 馃檪
Cheap as chips too 馃榾
bugzla 路
thanks mate have looked into it
1916baja 路
I think you'll find ians comment is a copy and paste from lowbugget.com.... They do vw turbo set ups. That's where Ian and rose got their turbo motor from.
bugzla 路
thanks buddy
ian.mezz 路
http://www.lowbugget.com/main_page.html
autobarn etc sell the holley pumps & regs .
