WTB Engle 110 cam & gear - sorted now thanks. Ignition barrel?
https://forums.aussieveedubbers.com/threads/98539/wtb-engle-110-cam-gear-sorted-now-thanks-ignition-barrel
Jimmy Wackburns ·
Hi, I'm after and Engle 110 cam & gear or similar from another manufacturer. Late model dished. What other performance parts might someone have for a 1916? Heads at the moment have standard sized valves but would like bigger. I live in central west NSW & travel to Syd often.
Cheers Jimmy
cnfabo ·
ring rod penrose....
1916baja ·
Rod x2.
type3vw ·
Engle and scat cams only have flat cam gear so you will have to buy an oil pump to suite.
1916baja ·
http://www.rodpenroseracing.com.au/index.php/product/cid-53
Available new from Vintage at Campsie or posted to you direct 9789-1777
OZ Towdster ·
Leons Motors in Brisbane have one on the shelf too
Gracey ·
I've got a scat C35 if you're interested. Same cam.
Personally I wouldn't use an Engle 110 or Scat C35, there are better choices out there.
yep scat C65 much better
Jimmy Wackburns ·
Thanks guys. I've been on Rod's website and am ordering everything I need from him. Good range and good prices. While I'm at it, does anyone know where I can get an ignition switch and barrel for a '68 beetle. The barrel has vw part no. 111 905 889 and the switch 311 905 855. I've resorted to starting my rat daily driver with a screwdriver. Guess you can't get much rattier than that.
Cheers Jim
VVDS 02-9789-1777
