I have what I believe is a twin SU manifold for a 36 or 40 hp motor It has the marking "DC552" on the smaller of the manifolds
See attached photos
Can any one confirm that this is a Monaro brand manifold and how do you tell the difference between the 36 and 40 HP manifold ??
Grasack ·
more photos
LUFTMEISTER ·
Now all you need the linkages and 1 1/8 H1 SU carbys and linkages and air filters.
36hp and 40hp are different diameters at the head, 36 obviously being the smaller
yep 36hp are smaller
very nice set up for the early sixties performance gear
Grasack ·
Thanks Guys
Do you know the dimensions of the 36 and 40 HP heads ? And what is it measured at OD or ID ??
Any Idea of value on the market ??
LUFTMEISTER ·
Looks like they have been bastardised to take later h2 carbs? Are there studs welded on the top and bottoms with threaded holes below them?
Grasack ·
You"re spot on there. Yes they appear to have the studs welded on and there is a threaded hole below them
What is the h2 carby
LUFTMEISTER ·
H2 is a later model su carbs. The base gaskets below show the difference between a h1 & h2 mounting flange.
