BrisDubba wrote:After rekitting the solex 34's in my 75 bay - the right carb is seeping fuel through the shaft (well that what is seems to be anyhow)
I believe they are able to be rebushed/ rebuilt - anyone done this before - any suggestions.
Peter
Hi Peter
to get them rebushed the hole is drilled larger then a bush is fitted.
Carburetor specialists would do this..
sounds like the fuel is running over the shaft/flap and out the shaft...
so, maybe the needle and seat aren't working when the bowl is full of fuel..
or too much fuel pressure from Your pump...
only need a couple of PSI.. [2psi]
Your pump may need shimming to lower the pump pressure..
if its an original vw pump
I have always oiled All moving parts on a carburetor
[just like VW mechanics did back in the 50s and 60s..]
this will help stop most wear...
