thread reapir
https://forums.aussieveedubbers.com/threads/98574/thread-reapir
71dub ·
Hi any one of anybody in brisbane who can repair the threadsb in the steering wheel of a super bug where the srews fit to secure the horn ring .I have two that are stripped and dont want to get another steering wheel .
regards barrie
greedy53 ·
could you redrill using a bigger bolt or fill it with a resin or the 2 piece epoxy stick you mix the 2 bits together and away ya go can be drilled when set
good luck
Just put in slightly larger screws, even self tapping screws will work there I believe
psimitar ·
I wonder how small helicoils go too?
Epoxy putty may hold the spring tension of the horn ring.
I think I'm right in saying the hub itself is alloy so welding is out.
Hmm, as the screws are 'special' then you could re-tap to M4 with a blind tap so the M4 screw bottoms out so the screw stays tight and cut the screw to length than that works or dill thro the hub to put a nut on the other side.
Old Dubber ·
Bring it over to me I will fix it for you
Grahame
71dub ·
hi grahame thanks for that have just bought helicoil kit from the uk to repair.
