tar76 wrote:Do you let it warm up before driving or do you just jump in and go?
The idea of the automatic choke which was a big selling point of beetles in the 60s
You get in push the accelerator down once
[to bring the automatic choke into action]
then start the engine and Drive off...
Don't warm up the engine by idling..
the automatic chokes do need some adjusting between winter and summer etc.
You loosen the automatic choke by the 3 screws holding it in place.. just loosen the 3 screws and turn the choke unit
anticlockwise for More choke...
clockwise for less choke..
If You take the air cleaner off You can see the choke flap close over [more choke - more strangler in the UK] lol
just adjust it.. engine cold... and see how the engine starts..
the wire to the automatic choke heats the choke up and once it gets to the correct temperature the choke is completely OFF...
also check the stepped piece that adjusts how much throttle
is applied when the choke is cold...
adjustment screw also... Best not to have your engine revving too fast when You first start it...
