The transaxle in my 75 L bug has been losing reverse (again) for quite a while now (backing trailers too often), and it finally got too bad, so I swapped it with a $100 'mystery' trans. that I bought from Lithgow a few years ago.
My L bug trans. is single side plate, and the trans. I have replaced it with is a double side plate. I also had to change the nose cone as the one on it was 2 holes for the mount, and mine is 3 holes for the mount.
I then found that the holes for the rear mounts had metal 'plugs' in them - I think I saw them in a thread some time ago, and I think it means it is a type 111 trans.
The question is, does anyone have any idea of that the difference in the ratios and/or diff may be between the 2 transaxles?
It is only temporary untill I can afford to get Dangerous (I hope) to work magic on my 'good' transaxle (well, good except that it also has a shot reverse), but if I need to be carefull about engine speeds (mainly on the highway), I would like to be aware of it.
beetleboyjeff ·
