65 Splitscreen Project - ***SOLD***Deposit Taken
https://forums.aussieveedubbers.com/threads/98706/65-splitscreen-project-solddeposit-taken
TOY-930 ·
Time to sell my splitscreen project ..i've had this now for almost 2 years and as the saying goes too many projects not enough time
This is a great project with (like all splitty's) some good points and some bad.
THE GOOD:
It has a great roof with only surface rust (no rusty gutters)
It has a solid cargo floor with only the first 200mm needing replacement and a couple of patches required
It is 95% complete with the all the hard to find bits including front seats & rear apron.
It comes with all replacement panels pictured
All glass included.
Gauges included.
underneath is reasonably solid. jacking points and outriggers could be repaired (except for left rear which will need replacement)
It's straight.. and would make an easy rat!
THE BAD
No Motor!
Reduction box is currently stuck and bus will not roll? (cant work it out) - It does come with an extended swing axle box - ready for an easy rear end drop
Cabin floor needs complete replacement (complete floor supplied)
Rear Corner (battery tray area) needs work..'D' pillar required and available through local suppliers. battery tray and rear corners supplied.
Some rust in the belt line area at the rear. (part fixed and part cut out)
Front screen area has rust at the bottom..replacement supplied
A Pillar rusty but replacement supplied.
Passenger door is an early door and will need to be swaped for a later door
Basically this is solid split project which is almost complete including almost all replacement panels (approx $2K worth)
Please pm me if interested..inspection will not dissapoint!
Price - $old
Thanks,
Adam
TOY-930 ·
more pics...
TOY-930 ·
more again...
